Hello when I go into site text Im looking for a specific text on the trust levels. I want to edit it so that when you go on your profile on the part that shows trust level New user or leader etc I want to change that text so I.E change New User to Just Starting not the badge name only but also that text itself
I think those would be groups.default_names.trust_level_0 and so on (change 0 to 1/2/3/4)
Do you mean these?
If so, they’re not connected to renaming the trust level groups. The site texts for those all begin with trust_levels.names, if you add that to your customise site text search box it should bring them all up:
Thanks @JammyDodger after going to
and changing it it worked
@NateDhaliwal Your solution would work but I’m not looking to change the group only I also wanted to change the Profile section
