サイトのロゴとして「サイトタイトル」がもうサポートされていない?
Instead of the site name, i’m getting this:
I was using the Title setting previously for one of my sites, which worked for me and showed up as the site’s main logo
Is Discourse forcing us to populate a logo now, is this a regression, or have I missed something?
「いいね!」 1
Same problem on my Discourse instance after last update.
I solved by deleting both Discourse logos in Admin settings (screenshot after deletion):
「いいね!」 5
Doh! :man_facepalming: Should have tried that! Thanks! :blush:
「いいね!」 1
You’re welcome :wink:
「いいね!」 1
This is a known issue, should be fixed before the weekend. But yes, deleting the logos is the workaround until the fix is out.
「いいね!」 6
Apologies! This is fixed in
https://github.com/discourse/discourse/commit/1981add261aacc279c26f5e684ae4a080607e73f
「いいね!」 6
It turns out the value of a text override can be null or '' so I had to add another migration to follow up.
https://github.com/discourse/discourse/commit/cb1f909fa4e4edb7b9d05c296ee090c30aecbd95
「いいね!」 7
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
