๐Ÿ‡ต๐Ÿ‡ฑ Dictionary of Polish translations
ืกื™ื›ื•ื ืžื‘ื•ืกืก ื‘ื™ื ื” ืžืœืื›ื•ืชื™ืช
The discussion revolves around the Polish translation of the Discourse glossary. fenio inquires about the usage of certain terms, specifically โ€œlikeโ€, and suggests that โ€œpolubieniaโ€ (similar to โ€œlikesโ€) might be a more suitable translation. He also questions the origin of the current glossary. Mespi agrees with fenio, suggesting alternatives such as โ€œpodoba siฤ™ x uลผytkownikomโ€ to avoid grammatical issues. MakaryGo offers help and proposes considering the switch to Crowdin for translations, but fenio suggests that the current platform can be adapted, and invites others to contribute to the translation process.
Is there anyone here from the Polish translation coordinators/reviewers?
I would like to discuss the glossary used in the translations.
https://www.transifex.com/discourse/discourse-org/glossary/pl_PL/?page=10
As I understand it, one should adhere to these entries?
like = lajk
likes = lajki
like = lajkowaฤ‡
I know that the SJP (Dictionary of the Polish Language) allows such forms, but in my opinion, this is rather colloquial vocabulary, and in translation, I would prefer simply โ€œpolubieniaโ€ (likes/favorites), which is not an awkward term.
Was this glossary created after any agreements?
I dug this up because, generally, the Discourse translation is inconsistent in places, and I started unifying it, and then I suddenly discovered the glossary :slight_smile:
3 ืœื™ื™ืงื™ื
In my opinion, likes would be a better option. Alternatively, instead of โ€œlikes,โ€ we could implement โ€œliked by x users.โ€ Then there would be no need to worry about incorrect endings.
2 ืœื™ื™ืงื™ื
Iโ€™d be happy to help! I just wonder if it wouldnโ€™t be better to strike right here
2 ืœื™ื™ืงื™ื
Not the best thread, but thatโ€™s rather irrelevant.
Everything can be changed, of course. Whatโ€™s more! You can change it yourself if you join the translation efforts :slight_smile:
