Staff can ignore tag requirements?
The discussion revolves around whether staff members should be allowed to ignore required tag settings in certain categories. AstonJ notes that the interface labels tags as ‘optional’ even when they are required, which leads moderators to skip tagging. codinghorror suggests removing moderator status as a punitive measure, a proposal Qqwy finds harsh and instead recommends a warning system to prompt staff to consciously decide when to bypass tag requirements. davidkingham points out that staff, like others, can forget, while MarcP emphasizes the importance of tags for automated integrations, highlighting the need for consistency.
For categories with required tags, it says tags are optional.
This is also leading to some moderators posting items without tags as I guess it’s set so they can ignore the setting? (I think it may be better if all users follow the requirements for the category.)
I suggest you remove moderator status from these users to “encourage” them to remember.
I run into this as well. They’re human, they forget. Why would a mod not need to add a tag if it’s required in that category?
It’s easily done - especially if not all categories require a tag and when the input box says ‘optional’. If it is not optional it should not say it is optional.
This seems like a very harsh approach.
Could you elaborate why tags are optional for staff members even in categories where they are required?
Another approach would be to show a warning message if a staff member attempts to create a topic without tags in a category where it is required. This way, they can ignore the restriction if they have to, but at least make a conscious choice.
Hmm.. interesting topic. I also tried to setup a required tag with the intention to make myself (admin) never forget to tag a post in a specific category. Very important if you have chat-integrations setup to external channels - because tagging afterwards does not trigger a push.
