STL, DXF and STEP viewer plugin wanted
Hi,
one of my Discourse communities is very specialized on CAD construction. Therefore I’m looking for a easy-to-use way of embedding the most common construction file formats. Has someone else any kind of solution?
Something like this: Have a try!
Or do you guys think we’re able to embed those A360 viewer?
https://360.autodesk.com/viewer
(ahhh they have a limitation at storing time: max 30 days)
My preferred way is: Uploading the right file format → getting an viewer with UI elements and download option.
Other thoughts appreciated.
##Update #1:
I found something similar at FormLabs Community forums:
It should be possible to embed the STL viewer from GitHub, but it’s limited to STL and it requires Javascript (i.e. it’s not an <iframe>).
「いいね!」 2
ウェブサイト上で STL ファイルを表示するために、これを使っています:Stl Viewer Javascript Plugin- Docs
これ用のプラグインがあれば素晴らしいですね。
「いいね!」 3
