nineb
19 בספטמבר, 2025, 1:07am
1
I don’t want a swap. I will risk OOM. Are there command line switches implied here to constrain RAM under 2gigs?
This seems to need to be increased. As @Canapin pointed out with my topic having 4g of ram was not sufficient.
And as I mentioned in my topic the instructions for adding a swap file should be added to git hub install instructions even if just an option if 4g of ram or less.
This instance will have at most 10 users. That’s right. TEN. Likely a frequent THREE users.
The default of 1 GB RAM works fine for small Discourse communities. We recommend 2 GB RAM for larger communities.
# Install Discourse on a Cloud Server
> To install and self-host Discourse, follow the steps below. But if you'd rather skip the setup, maintenance, and server management, our official Discourse hosting takes care of everything for you.
> [Learn more about Discourse hosting](https://discourse.org/pricing)
> If you prefer to self-host but need help setting it up we have partners who can help.
> [Click here to explore self-hosting set-up options](https://discourse.org/partners).
**Set up Discourse in about 10 minutes** with zero knowledge of Rails or Linux shell. Works on any Docker-compatible cloud provider or local server.
## Contents
- [Quick Start](#quick-start)
- [Requirements](#requirements)
- [Installation](#installation)
- [The Setup Wizard](#the-setup-wizard)
- [After Installation](#after-installation)
- [Advanced Configuration](#advanced-configuration)
- [Troubleshooting](#troubleshooting)
This file has been truncated. show original
So I provisioned a non-refundable 1c2r. That’s it. No upgrades. Swap takes too much space. So pass.
frustrated
pfaffman
(Jay Pfaffman)
19 בספטמבר, 2025, 1:28am
אתה כנראה לא יכול לבנות קונטיינר בלי swap. אתה יכול לנסות ליצור את ה-swap, לבנות את הקונטיינר, לכבות את הקונטיינר ולהסיר את ה-swap.
אתה באמת לבד עם זה. אני ממליץ בחום לא לנסות לעקוף את דרישת ה-SWAP. עליך ליצור קשר עם ספק הענן שלך כדי שיספק לך דיסק גדול יותר.
nineb
29 בספטמבר, 2025, 9:23am
4
ניסיתי את הדבר הכי קרוב עם שתי חלונות SSH. צור swap, הפעל את ה-launcher, בחלון SSH אחר מחק את ה-swap, ה-launcher המשיך. וזה עשוי לעבוד על VPS עם הקצאה טובה יותר. בפעם הבאה שיהיה לי פנאי אנסה זאת. יש לי כעת מופע שרץ על 4c12r
נתון: לא ניתן להגדיל משאבים
הצעה: הגדלת משאבים
Ed_S
(Ed S)
29 בספטמבר, 2025, 12:44pm
5
בדרך כלל אתה צריך יותר זיכרון (RAM+swap) לעדכון מאשר לשירות רגיל.
אם אין לך מקום ל-swap, זה בגלל שנתוני הפורום שלך (מסד נתונים+העלאות) משתמשים במקום שאתה צריך.
זה אפשרי שתוכל לעקוב אחר האסטרטגיה
או האסטרטגיה
העבר את הנתונים שלך בכל פעם להתקנה חדשה ומעודכנת
אבל עשיתי מאבקים משלי עם מופע בגודל מינימלי, תוך שימוש בעשרות שנות ניסיון במערכות שלי. בסופו של דבר, היה עדיף להשתמש במכונה גדולה יותר. למעשה, עדיף מאוד, מכיוון שהמכונה הגדולה יותר הייתה זולה יותר. הסיבה לכך היא שספקים שונים גובים סכומים שונים - עברתי מ-Digital Ocean ל-Hetzner.
pfaffman
(Jay Pfaffman)
29 בספטמבר, 2025, 3:10pm
6
אפשרות אחרת, שתדרוש הרבה עבודה, תהיה לבנות את התמונה החדשה במכונה אחרת, לשים אותה במאגר כלשהו, ואז להפעיל אותה במכונה עם משאבים מוגבלים.
אבל זה מעבר לסוג העזרה שניתן לספק בפורום.
I guess the key takeaway was
and not
which was merely a suggestion to a path forward.
