It doesn’t matter what I use on Tags are visible only to following groups it will disapper right away from there if a reload, visit some other page and then come back or doing log out/login.
If I don’t return to tag group settings I can see that limited tga under its group on tag page. But it isn’t limiting anything.
Here I can limit visibility of one tag to TL2 but lower TLs see it anyway.
And those would be what? I’m trying to limit visibility using trust level. But I don’t understand why even that could be play any roll. It is a tag group and there isn’t any other settings that could affect.
So you can limit visibility of a tag? Don’t care so much about that disappearing setting — there is a couple similar cases and I’m quite sure it comes from iPadOS and/or DiscourseHub.
I did upgrading something like 12 hours ago and can, of course, tell exact build, but this has been issue now quite long time. I should tell earlier, but I forgot, and now I needed that feature again.
I should limit away every component before this posting but that is a bit time consuming between everything else, but if you all really can limit visibility then I have to (but tag groups have certain history break every now and then )
This starts to be interesting. No matter if I tried win-laptop, several browsers, iPad/iPhone… no luck.
But if used selfmade group as limiting one it stayed. A little bit more digging and one issue is automated groups that is translated. Like trustlevel_x vs. Finnish luottamustaso_x. Dsicourse just doesn’t accept translated ones. Well, with tag groups anyway.
And yet my TL1 users sees tags no matter what limiting group I’m using.
Edit:
I can’t change default locale from finnish to english(US). That is by design, I guess. So trying how it works when locales are… default ones, is quite impossible to me.
