Tags on categories playing around
Hi,
On categories I am using " Tags that can only be used in this category:"
All the upper case tags are automatically converted to lower case. This creates an issue that these tags are not comming up if the user enters it in upper case.
Example, for abreviation, I have tag “WAF”, when I enter this tag in tags tab into category it is converted into “waf”. As it is abbreviation so most of the users uses it as “WAF” and this does not show the tag, as the system converted it into lower case.
Any help will be appreciated.
The tag search is not supposed to be case sensitive, but was and showed strange behaviour. I fixed it so it will match and select “waf” if you enter “WAF”.
「いいね!」 3
