Threaded comments when using Discourse for website comments?
I am looking into using Discourse for comments on a website of mine.
Is there a way to display the comments in a threaded style, like Disqus does by default (Example: Optimized Ionic-Angular CSS Bundle for PWA :: Julien Renaux - Fullstack Software Engineer & founder | AI guru)?
(After reading through Plugin: Ask me anything or Q&A format (threaded replies) and related and similar topics, this doesn’t really seem to be supported (yet))
Discourse displays replies in flat form,though the threading is clear from the formatting. Discourse will likely never display threaded comments.
What do you mean by that?
Look above this post in the top right, you’ll see your avatar, showing that I clicked “reply” on your earlier post. You can click it to expand.
Similarly, you can see on your post above that it says “2 replies” - click that, and this post will appear underneath
Thanks, got it.
Hiding the “replies” in the direct view and triggering all these AJAX requests would be the view I am looking for :wink:
なぜスレッド形式のコメントが一切表示されないのですか?
これは Discourse の設計における基本的な決定です。詳細については、共同創設者の一人によるこのブログ記事をご覧ください Web Discussions: Flat by Design
@danyalamriben さん、私のプラグインをご覧ください:
https://meta.discourse.org/t/fast-quote-plugin/120427?u=merefield
ありがとうございます。試してみますので、後ほどご報告いたします!
