شريط التمرير للمواضيع لا يتحدّث بسبب تخصيصات CSS
I think I’ve broken something on my discourse installation - scrollbar is no longer updating when scrolling.
i.e. the indicator 1/25 changes to 2/25 and then remains at 2/25 for the remaining 23 posts. Also the URL of the topic no longer updates to ...../<post_number>
In the javascript console I can see strange error messages:
_ember_jquery-0ae86c…ee94f26d9c3.js:5106 [Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
_ember_jquery-0ae86c…ee94f26d9c3.js:1975 [Violation] 'setTimeout' handler took 886ms
[Violation] Forced reflow while executing JavaScript took 79ms
_ember_jquery-0ae86c…e94f26d9c3.js:61218 [Violation] 'click' handler took 167ms
[Violation] Forced reflow while executing JavaScript took 45ms
Any idea how to debug this issue ?
Many thanks
You will need to provide a link (preferably) or the full error for us.
Please try this one
https://discourse.mfc.bayern/t/feedback-sur-le-nouveau-site/6125
When I use the safe mode to deactive the theme modifications, it works well : https://discourse.mfc.bayern/safe-mode
Probably a script that breaks the timeline
actually it looks like it is a CSS breaking the timeline ! If I remove loading of https://www.mfc.bayern/assets/css/headerfooter-style.css then it works
Any hint how a CSS may break the timeline (which I assume is javascript based) ?
You you change the heights in the wrong place, it will break the JS that detects scrolling.
which heights ? searching for height in the CSS yiels 140+ results :frowning:
OK found it
html,
body {
height: 100%; }
