Translation bug, and logo problem
Logo is not displaying, but by holding i can open image on the new card
Polish Language → [missing %{count} value]
Discourse Version:
Edit:
I checked, and there is a bug. The first time you enter the site, the logo is visible. After logging in and out, the logo crashes again :confused:
I believe the second screenshot gives you the answer, there is an option to force https in the discourse parameters/security tab
In your browser console you can see:
Chargement du contenu mixte d’affichage « http://forum.mystermc.pl/uploads/default/original/1X/61433630046b732899eab0721da7dcb839bd7c5e.png » (non sécurisé) sur une page sécurisée
(sorry for the french :sweat_smile: )
As for the translation problem, it might have to wait a little bit because off the transifex/crowdin swtich, I saw a post dedicated to polish translation… here !
Fource https don’t fix that :confused:
I have checked with reseting cache
Maybe nginx configuration?
I have redirect from http to https
hum…:thinking: doesn’t seem likely
You still have the “http mixed” warning though, could you try to re-upload your logo? it’s the favicon, which is an optimized version of the logo, that causes it :
http://forum.mystermc.pl/uploads/default/optimized/1X/61433630046b732899eab0721da7dcb839bd7c5e_2_180x180.png
http://forum.mystermc.pl/uploads/default/optimized/1X/61433630046b732899eab0721da7dcb839bd7c5e_2_32x32.png
your logo being :
https://forum.mystermc.pl/uploads/default/original/1X/61433630046b732899eab0721da7dcb839bd7c5e.png
with force_https enable, the optimized versions of it should also show as https after re-upload :crossed_fingers:
Works! Thank You for help!
