"Triage posts using AI" script of "Automation" plugin always includes image data in request
A bug has been reported in the Discourse Automation plugin’s “Triage posts using AI” script, where image data from posts is always included in AI requests, even when the “Max Post Tokens” limit is set and vision is disabled. This leads to excessive token usage, undermining efforts to control costs when using hosted or third-party LLMs. The issue is reproducible and impacts scenarios where only text content is relevant. The problem is acknowledged and will be fixed by PR #36871. per1234 reported the issue, and zogstrip confirmed the fix is in progress.
Priority/Severity:
Medium
Platform:
Discourse b66fca70d0e3d12ef930398289fac5269cd240c7
Description:
The official “Automation” plugin has a “Triage posts using AI” script. This script provides the content of a post to the LLM, then performs configurable triage actions depending on the result.
In order to keep the LLM usage within the credit allocation provided by the Discourse hosting plan (when using the CDCK hosted LLM) or within budget when using a 3rd party LLM provider, it is important to manage the number of tokens required for each query. The “Triage posts using AI” script provides a “Max Post Tokens” setting that allows setting a limit on how much of the post content will be included in the request.
:bug: If the post has attached images to a post the massive quantity of image data is always included in the request, even when this results in exceeding the post token limit set for the automation via the “Max Post Tokens” setting.
This occurs even when the “Vision enabled” option is disabled in the configuration of the AI persona used by the automation.
This results in uncontrollable token expenditure.
In many use cases, it is only the text data of the post that is of interest, in which case the image data blowing up the token usage is not even of value.
Reproducible steps:
  1. If you don’t already have a suitable custom AI persona, create one.
  2. Disable the “Vision enabled” option in the settings of the persona.
  3. If it isn’t already, enable the built-in “Automation” plugin.
  4. Navigate to the plugin’s “Automations” page (/admin/plugins/automation/automation).
  5. Click the “+ Add automation” button.
    The “Select a script” page will open.
  6. Select the “Triage posts using AI” script.
    The automation configuration page will open.
  7. Configure the automation as required for a simple test. It is not necessary that the automation result in the performance of any actions, only that it generates LLM queries.
  8. Select the AI persona you created in step 1 from the Script options > Persona menu in the automation configuration.
  9. Set the Script options > Max Post Tokens setting to 20 in the automation configuration.
  10. Click the “Update automation” button at the bottom of the automation configuration page.
    You will be returned to the “Automations” page.
  11. Set the “Enable automation” switch for the newly created automation to the “on” position.
  12. Compose a post or DM that will trigger the automation. Add an image to the post.
  13. Publish the post or message.
  14. Navigate to the administration page of the “Data Explorer” plugin (/admin/plugins/explorer).
  15. Click the “+” button on the page.
    A “Query name…” field will appear.
  16. Type Get AI Audit Logs in the “Query name…” field.
  17. Click the “+ Create New” button.
    A new Data Explorer query will be created.
  18. Click the “Edit” button.
    The query code editing field will open.
  19. Replace the contents of the placeholder query code with the following:
    SELECT request_tokens, raw_request_payload
    FROM ai_api_audit_logs
    WHERE feature_name = 'llm_triage'
  20. Click the “Run” button.
    :bug: The request_tokens field value shown in the Data Explorer query result for the request the automation generated after being triggered by your post greatly exceeds the number that would be expected to be used by the “System prompt” from the AI persona configuration and the maximum 20 tokens of post text context limit imposed by the automation configuration.
  21. Click the ●●● button to the right of the value of the raw_request_payload field in the Data Explorer query result.
    A dialog will open that shows the full value of the field.
:bug: The data of the image attached to the post was included via a messages[*].image_url key in the request data.
Example:
  "model": "Qwen/Qwen3-VL-30B-A3B-Instruct",
  "max_tokens": 16384,
  "messages": [
      "role": "system",
      "content": "You will be given a piece of text, and your task is to detect the locale of the text. Your response must be an IETF language tag code."
      "role": "user",
      "content": [
          "type": "text",
          "text": "title: Test of the automation\nThis is some English language text."
          "type": "image_url",
          "image_url": {
            "url": "data:image/jpeg;base64,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"
  "stream": true,
  "stream_options": {
    "include_usage": true
Additional context:
In addition to the excessive token usage, I have been encountering poor accuracy in the results from a trivial text analysis task (detecting the human language of the post). The occurrences have all been for posts which have attached images, and the fault does not occur if I manually provide the same post text to the same AI persona via a DM. This makes me suspect the image data included in the request may be the cause of the incorrect results from the automation.
I am experiencing the fault on the forum.arduino.cc forum.
Thanks for the report @per1234 :+1:
This will be fixed by
https://github.com/discourse/discourse/pull/36871
This topic was automatically closed after 2 days. New replies are no longer allowed.
