A common thing inside of Linux is that once a command has completed, then the cursor goes to the next line to await the next command.
The command you ran was wget and the flag you had at the end was -qO-.
This tells WGET to not output anything to the console, and to end the program once the download is complete. Nothing is wrong, it’s just silent. To make it output statuses to the console, remove the flag at the end. This applies for every WGET download.
It works fine on AWS both on the host directly and also in an LXD container as long as you launch the right AWS image. I have multiple Discourse installs running in LXD on AWS.
Use this image on AWS: Ubuntu Server 18.04 LTS (HVM), SSD Volume Type - ami-0a313d6098716f372 (64-bit x86) / ami-01ac7d9c1179d7b74 (64-bit Arm)
I also recommend following the official Docker install guide:
