This might be related:
Hmm, either I failed at deleting, or someone/something pushed it. I’ve now deleted it again.
However, I don’t think it’s the cause of the issue in this topic.
That is very surprising. If you’re on tests-passed, it should be 3.4.0.beta1-dev right now!
In your /var/discourse/containers/app.yml file, have you customized the version: key at all?
Not that I’m aware of. Discourse has been installed for 6+ months and I followed the basic setup instructions. I believe I have upgraded through the admin page before without issues.
version: is commented.
Here’s what I have in app.yml.
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
## Uncomment the next line to enable the IPv6 listener
#- "templates/web.ipv6.template.yml"
- "templates/web.ssl.template.yml"
- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
- "80:80" # http
- "443:443" # https
params:
db_shared_buffers: "256MB"
#db_work_mem: "40MB"
#version: tests-passed
content_security_policy: "frame-ancestors 'self' http://localhost:56174;"
env:
LC_ALL: en_US.UTF-8
LANG: en_US.UTF-8
LANGUAGE: en_US.UTF-8
DISCOURSE_ENABLE_CORS: true
DISCOURSE_CORS_ORIGIN: 'http://localhost:56174'
UNICORN_WORKERS: 4
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: redacted
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'discourse@redacted, keith@redacted'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: redacted
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: "redacted"
DISCOURSE_SMTP_PASSWORD: "redacted"
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
DISCOURSE_SMTP_DOMAIN: redacted
DISCOURSE_NOTIFICATION_EMAIL: redacted
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
LETSENCRYPT_ACCOUNT_EMAIL: redacted
## The http or https CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
## The maxmind geolocation IP address key for IP address lookup
## see https://meta.discourse.org/t/-/137387/23 for details
#DISCOURSE_MAXMIND_LICENSE_KEY: redacted
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- git clone https://github.com/discourse/discourse-topic-voting.git
- git clone https://github.com/discourse/discourse-solved.git
- git clone https://github.com/discourse/discourse-assign.git
run:
