取消更改时信任等级显示错误(不确定如何命名此问题)
So, I was attempting to change a user’s Trust Level, I cancelled the change by pressing the :negative_squared_cross_mark: and it ended up with a really peculiar outcome. It’s kinda hard to explain so it’s best if I provide reproductive steps.
  1. Go to /admin/users/[a user] and choose a Trust Level that is different to their current.
  2. Cancel the input by pressing the :negative_squared_cross_mark: like aforementioned.
  3. Go back to the dropdown list and you’ll notice that the Trust Level you attempted to change is no longer the level as before, the name stays the same, however.
This also results in you unable to set the trust level to that level unless you refresh the page. I don’t see this is expected behaviour. Here’s an example:
Personally, I can’t think of a scenario where this would this become aburden but I though I’d report it anyway.
4 个赞
Can we repro this @tshenry?
2 个赞
Yep, I can definitely repro.
5 个赞
Paging @j.jaffeux
4 个赞
That should fix it:
Probably worth a backport too.
5 个赞
