UI zegt dat ik een concept heb, maar dat heb ik niet
Users report a bug where the UI incorrectly shows a draft exists even when none is present. Falco notes the issue should be fixed by a recent commit and will be rolled out soon. nbianca confirms the fix is in place and asks users to test after updating. linzo initially confirms the issue persists in version 2.8.0.beta4, but after following sam’s suggestion to create and delete a draft, the problem resolves. griffin confirms the same fix works for them, with both users expressing satisfaction linzo and griffin.
This is on https://community.wanikani.com.
Should be fixed already by FIX: Update draft count after creating a post (#13884) · discourse/discourse@300db3d · GitHub which will be rolled out the linked site soon.
I also have this issue on my discourse and will be waiting for when the fix is rolled out.
The issue should be fixed by:
https://github.com/discourse/discourse/pull/13940
Please let me know if you are still able to reproduce it after updating your Discourse instance.
Surprisingly the issue is still there. Currently running 2.8.0.beta4.
Can you rebuild and ensure you are running latest tests-passed?
After rebuilding, nothing changed. I even restarted discourse to see if that does it, still the issue remained.
wait, can you try making a post now on your site. it should go away after you post something.
Once that is done does the issue repeat?
I see the exact same issue in the Let’s Encrypt community.
this actually fixed it :smiley:
made a new post and saved as draft, then deleted it. thanks @sam & @nbianca
I concur with @linzo’s results.
:partying_face:
This topic was automatically closed after 2 days. New replies are no longer allowed.
