I attempted to update docker_manager admin/upgrade
However, on the Upgrade docker_manager page, nothing happens. Instead the screen stays like the screenshot below indefinitely.
The solution is to do a command line rebuild.
Sometimes it’s worth refreshing that view of the progress - the browser doesn’t always auto-refresh in the intended way.
It can be useful also to look at the Processes view - that will give some hints as to whether things are moving forward or not.
I believe all you need to do is rebuild the application. You can run the below command on your terminal. I think it should do the trick
cd /var/discourse
./launcher rebuild app
