Aggiornamento docker_manager bloccato - 2.2.0.beta4
Hi all,
I’ve just tried to upgrade from 2.2.0.beta3 to 2.2.0.beta4 however Docker Manager would not upgrade at all. The Docker Manager screen shows an empty console and ‘Upgrading…’. Pressing Reset Upgrade throws a JS error (see screenshot). There’s nothing in syslog. The machine has 4GB ram & 4GB swap. I ran ./launcher rebuild app and the upgrade worked but I’d love to keep using Docker Manager. Any ideas?
Thanks,
Zach
Hmm this is odd and I’ve never seen this before. Try rebuilding from the console
cd /var/discourse
./launcher rebuild
Thanks for the quick reply, I tried ./launcher rebuild app initially and it worked fine going from beta3 to beta4, but Docker Manager still thinks it’s out of date and/or in the process of upgrading?
I just noticed the commit hash for docker_manager is different.
I ran
./launcher enter app
root@tarck-app:/var/www/discourse/plugins/docker_manager# git log --name-status HEAD^..HEAD
commit 61175ada7a1993647878c53320e9c6ffb1076dd2
So the repo is up to date but Discourse is showing an older hash (from Tuesday 18th Sep). I might try rebuild again and see what happens.
Okay no luck with rebuilding the container again. Any ideas?
Hmmm what is your app.yml, are you pulling docker manager plugin from a branch?
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/davidtaylorhq/discourse-whos-online.git
          - git clone https://github.com/znedw/discourse-poster-location.git
          - git clone https://github.com/znedw/discourse-word-replace.git
master, I think?
root@tarck-app:/var/www/discourse/plugins/docker_manager# git status
On branch master
Your branch is up-to-date with 'origin/master'.
nothing to commit, working directory clean
Are you 100% sure rebuild worked properly and did not error out somewhere?
As far as I remember the rebuild went fine, are the rebuild logs persisted or just written to stdout? I can probably run the rebuild again and paste the output somewhere?
I had the exact same issue: even after manual rebuild, docker_manager was stuck in “Currently Upgrading” state and the “Reset Upgrade” button was throwing an exception.
I fixed the issue by running this:
I’m having exactly the same problem except that the process has gone part way through and then stopped. I realize it says, “This will take a while” but I started this yesterday.
== Seed from /var/www/discourse/db/fixtures/500_lounge_category.rb
== Seed from /var/www/discourse/db/fixtures/501_meta_category.rb
== Seed from /var/www/discourse/db/fixtures/502_staff_category.rb
== Seed from /var/www/discourse/db/fixtures/600_themes.rb
== Seed from /var/www/discourse/db/fixtures/990_settings.rb
== Seed from /var/www/discourse/db/fixtures/990_topics.rb
== Seed from /var/www/discourse/plugins/discourse-narrative-bot/db/fixtures/001_discobot.rb
== Seed from /var/www/discourse/plugins/discourse-narrative-bot/db/fixtures/002_badges.rb
*** Bundling assets. This will take a while ***
$ RUBY_GC_MALLOC_LIMIT_MAX=20971520 RUBY_GC_OLDMALLOC_LIMIT_MAX=20971520 RUBY_GC_HEAP_GROWTH_MAX_SLOTS=50000 RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=0.9  bundle exec rake assets:precompile
This monkey patch is no longer required.
Purging temp files
Bundling assets
Thanks mate, this worked, can’t believe I didn’t see that post earlier. Upgraded docker_manager to the latest and all is well.
