「Uncategorized」カテゴリが親カテゴリとして表示されない
Continuing the discussion from Categories not showing up as Parent Category: I think have this issue too. The category “EthosCE Support” doesn’t appear as a parent category.
Is there any update on the bug fix?
Did you tried by disabling suppress uncategorized badge site setting?
Are you saying that you renamed “uncategorized” “EthosCE Support” and are now sad that you cannot use the category formerly known as “uncategorized” as a parent category?
I’m pretty sure that’s what you get for trying to use ‘uncategorized’ for something else.
@vinothkannans Yes, I disabled suppress uncategorized and was still not able to make it a parent.
I don’t think that under any conditions you can make uncategorized be a parent. If it’s a parent, then it’s not very uncategorized.
