Undo an Official Warning
:bookmark: This guide explains how to remove an official warning in Discourse via the console, particularly aimed at self-hosting users.
:person_raising_hand: Required user level: System Administrator
:desktop_computer: Console access required
In certain situations, a warning issued to a user may need to be retracted. This action involves removing the warning through the console, which is accessible for those with server access. If you are a hosted customer, please contact the Discourse team (team@discourse.org) for assistance with this process.
Understanding user warnings
Official warnings involve two pieces of data in the Discourse database:
  1. A record in the user_warnings table linking the warning to a user and topic.
  2. The associated private message topic has its subtype set to "moderator_warning".
To fully undo a warning, both need to be addressed: the user_warnings record must be deleted, and the topic’s subtype must be reset.
Removing an official warning
To remove a warning, follow these steps:
  1. Access the server console:
    • Use SSH to connect to your Discourse server.
    • Enter the console with the following commands:
      cd /var/discourse/
      ./launcher enter app
      rails console
  2. Remove the latest warning:
    If the warning you want to delete is the most recent one, execute:
    warning = UserWarning.last
    warning.topic.update(subtype: TopicSubtype.user_to_user)
    warning.destroy
  3. Find and remove a specific warning:
    If the warning wasn’t the last one, search for the specific warning using the user_id:
    UserWarning.where(user_id: the_user_id)
    This will return an array of warnings related to the user. Once you find the correct id, remove it using:
    warning = UserWarning.find(3)
    warning.destroy
Destroying the warning record and resetting the topic subtype will remove the warning from the user’s warning count and unmark the PM as an official warning. The private message itself will not be deleted.
Is there any chance you could share the steps that I’d need to take to log in to the Console? I’ve tried Googling this but every guide seems to assume that the user will know how to do that.
Assuming you followed the standard installation guide, you would SSH into the server and run:
cd /var/discourse/
rails console
Hey @JammyDodger . Maybe there needs to be a magic link that links “console” and/or “rails” (or maybe “rails console”) to
Hmm. That’s an idea. :thinking: I’ve been burnt with these before though. :slight_smile:
Let me keep an eye out now you’ve said it and see how often it comes up. :+1:
We are going through the docs at the minute, so maybe in this case it would good to add the full instructions in the guide.
Or maybe the section will be “stuff you can do in rails” and the About or whatever will be enough.
Surely it’d be much easier to handle these as penalties and have a log of all official warnings sent for administrators and moderators to manage at any given time? It makes it very difficult when a moderator accidentally warns a user with a similar name and then has to reach out to the site maintainer for them to resolve the problem.
I think there’s a Contribute > Feature request for it here:
Is there any way to also do this via API and not just via rails console?
