Undo official warning
Is it possible to “undo” an official warning? When moderator sends a warning and it turns out that user shouldn’t have got it, can the warning be cancelled? I don’t seem to find any information about it in meta.
3 Me gusta
Not really, short of accessing the console directly.
3 Me gusta
How would you delete an official warning from inside the console? Or how would you convert a warning to a regular message?
Warnings are in the user_warnings table. If the warning you want to delete is the last warning that was created on your site, you can do that with:
UserWarning.last.destroy
If the warning wasn’t the last warning, you can find the warning by searching for user_warnings by user_id:
UserWarning.where(user_id: the_user_id)
This will give you an array of warnings for that user. You can then destroy the warning by using the warning’s id. For example:
UserWarning.find(3).destroy
Destroying the warning will leave the PM in place. The PM will no longer be a warning.
10 Me gusta
Cerrado en favor de Proposal: Undo Official Warning
