Upgrade eindigt met FAILED TO BOOTSTRAP
I tried unsuccessfully to upgrade. Any advice?
DISCOURSE DOCTOR output
Stable is broken at the moment. I recommend following our default release channel, or waiting until a fix for
https://github.com/discourse/discourse_docker/pull/484
@Falco - Thanks for your response and explanation. What does it mean
? Did I do something wrong? My steps:
  • I started the update in admin/upgrade. There were several components to update, but only Docker was clickable (green).
  • It was successful, but without instructions on how to proceed. Refresh displayed the instructions from step 2.
  • I did that with this unhappy result. :confused:
I added dummy themes:update task in both stable and beta.
https://github.com/discourse/discourse/pull/11261
https://github.com/discourse/discourse/pull/11262
Good job! :+1: @dan Thanks :heart:
