What Causes Error rake Aborted StandardError
In a discussion titled ‘What Causes Error rake Aborted StandardError’ under the Installation category, Aaron_Walsh reports recurring failures when using their Discourse server, requiring ./discourse-doctor each time. The error stems from a missing ‘hnsw’ access method in PostgreSQL, traced to an outdated Vector extension. merefield suggests updating the Vector extension via a linked guide, noting it’s often required when using AI-related plugins. Aaron_Walsh confirms attempting the fix but reports command failures, including ‘user postgres does not exist’ and ‘command not found’ errors 4. Later, Aaron_Walsh verifies the Vector extension is installed (version 0.7.2), and merefield confirms this is correct and asks if the build now succeeds. merefield and 8 clarify the issue was running commands outside the Docker container — a common pitfall. Aaron_Walsh acknowledges the mistake and confirms following the linked solution successfully. merefield concludes that the multi-layered shell environment can be confusing, especially with three levels of prompts. The root cause was an outdated Vector extension and incorrect command execution context (outside the container).
Every time I come to use my Discourse hosting server, it always fails, and I need to use ./discourse-doctor. Why is this?
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled: (StandardError)
PG::UndefinedObject: ERROR:  access method "hnsw" does not exist
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:55:in `block (2 levels) in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract_adapter.rb:1028:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.3.4/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract_adapter.rb:1000:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:54:in `block in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.3.4/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract_adapter.rb:1143:in `log'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:53:in `raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/database_statements.rb:521:in `internal_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/database_statements.rb:131:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/query_cache.rb:25:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:47:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration/default_strategy.rb:10:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1047:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1017:in `block in say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1017:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1036:in `method_missing'
/var/www/discourse/plugins/discourse-chatbot/db/migrate/20231026010114_create_pg_vector_chatbot_post_embeddings_index.rb:5:in `up'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:989:in `public_send'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:989:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:970:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:969:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:227:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:968:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1178:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1529:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1580:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1528:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1503:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1503:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1448:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1600:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1448:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1274:in `up'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/migration.rb:1249:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/tasks/database_tasks.rb:243:in `migrate'
/var/www/discourse/lib/tasks/db.rake:259:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:234:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
Caused by:
ActiveRecord::StatementInvalid: PG::UndefinedObject: ERROR:  access method "hnsw" does not exist (ActiveRecord::StatementInvalid)
Caused by:
PG::UndefinedObject: ERROR:  access method "hnsw" does not exist (PG::UndefinedObject)
Tasks: TOP => db:migrate
I, [2024-08-03T09:46:43.636707 #1]  INFO -- : gem install tokenizers -v 0.4.4 -i /var/www/discourse/plugins/discourse-ai/gems/3.3.3 --no-document --ignore-dependencies --no-user-install
Successfully installed tokenizers-0.4.4-x86_64-linux
1 gem installed
gem install tiktoken_ruby -v 0.0.9 -i /var/www/discourse/plugins/discourse-ai/gems/3.3.3 --no-document --ignore-dependencies --no-user-install
Successfully installed tiktoken_ruby-0.0.9-x86_64-linux
1 gem installed
gem install multipart-post -v 2.4.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.3 --no-document --ignore-dependencies --no-user-install
Successfully installed multipart-post-2.4.0
1 gem installed
gem install faraday-multipart -v 1.0.4 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.3 --no-document --ignore-dependencies --no-user-install
Successfully installed faraday-multipart-1.0.4
1 gem installed
gem install event_stream_parser -v 1.0.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.3 --no-document --ignore-dependencies --no-user-install
Successfully installed event_stream_parser-1.0.0
1 gem installed
gem install ruby-openai -v 7.0.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.3 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-openai-7.0.0
1 gem installed
gem install google_search_results -v 2.2.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.3 --no-document --ignore-dependencies --no-user-install
Successfully installed google_search_results-2.2.0
1 gem installed
gem install wikipedia-client -v 1.17.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.3 --no-document --ignore-dependencies --no-user-install
Successfully installed wikipedia-client-1.17.0
1 gem installed
gem install childprocess -v 5.0.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.3.3 --no-document --ignore-dependencies --no-user-install
Successfully installed childprocess-5.0.0
1 gem installed
== 20231026010114 CreatePgVectorChatbotPostEmbeddingsIndex: migrating =========
-- execute("      CREATE INDEX pgv_hnsw_index_on_chatbot_post_embeddings ON chatbot_post_embeddings USING hnsw (embedding vector_l2_ops)\n      WITH (m = 32, ef_construction = 64);\n")
I, [2024-08-03T09:46:43.638198 #1]  INFO -- : Terminating async processes
I, [2024-08-03T09:46:43.638280 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 36
I, [2024-08-03T09:46:43.638349 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 98
98:signal-handler (1722678403) Received SIGTERM scheduling shutdown...
2024-08-03 09:46:43.639 UTC [36] LOG:  received fast shutdown request
2024-08-03 09:46:43.649 UTC [36] LOG:  aborting any active transactions
2024-08-03 09:46:43.653 UTC [36] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
98:M 03 Aug 2024 09:46:43.654 # User requested shutdown...
98:M 03 Aug 2024 09:46:43.655 * Saving the final RDB snapshot before exiting.
2024-08-03 09:46:43.658 UTC [46] LOG:  shutting down
2024-08-03 09:46:43.723 UTC [36] LOG:  database system is shut down
98:M 03 Aug 2024 09:46:43.865 * DB saved on disk
98:M 03 Aug 2024 09:46:43.865 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1463 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
033d28baebcc9523d8c3865998e94ad18e7b6db72a1a4ab604fe0684e7c3ca8b
root@ubuntu-s-2vCPUs-4gb-amd-nyc1-01:/var/discourse#
Looks like you may be trying to use Chatbot or AI Topic Summary whilst your Vector Postgres extension is not up to date?
Follow the resolution here:
It’s also in the setup section of the Plugin Topics :wink:
I do indeed remember this, so it is my fault!
However, I failed to mention at the time that this does not work for me. I have tried numerous ways, and the files cannot be found according to the console.
root@ubuntu-s-2vCPUs-4gb-amd-nyc1-01:/var/discourse# su postgres -c 'psql discourse'
\dx
ALTER EXTENSION vector UPDATE;
\dx
su: user postgres does not exist or the user entry does not contain all the required fields
Error: Can't open display: unix:0
ALTER: command not found
discourse=# postgres -c 'psql discourse'
discourse-# \dx
                                    List of installed extensions
   Name   | Version |   Schema   |                            Description
 hstore   | 1.7     | public     | data type for storing sets of (key, value) pairs
 pg_trgm  | 1.5     | public     | text similarity measurement and index searching based on trigrams
 plpgsql  | 1.0     | pg_catalog | PL/pgSQL procedural language
 unaccent | 1.1     | public     | text search dictionary that removes accents
 vector   | 0.7.2   | public     | vector data type and ivfflat access method
(5 rows)
This looks good now.
Will it build now?
This failed because you weren’t in the container. But believe you figured that out.
You weren’t in the container. You have to enter it first.
Yes, silly me! I did what the other person did in the topic you hyperlinked. D’oh!
All good. Too many levels of prompts. Can be very confusing. 3 levels in this example. :sweat_smile:
