Hopefully a simple question that I’m over-complicating, but I cannot figure this out. Is there any way to upload an image to a post without embedding it? Basically, I’d want to attach an image file like you would a PDF so that it’s downloadable by clicking it.
In a Support thread titled Upload an image without embedding it, codechef asks how to upload an image as a downloadable attachment (like a PDF), rather than embedding it inline. supermathie suggests manually editing the Markdown to create a hyperlink or HTML attachment tag, though notes that browsers won’t force downloads due to server headers. codinghorror cautions this is a “hacky” workaround and proposes using angle-bracketed URLs, but codechef finds those still open in-browser. codinghorror suggests right-clicking to “Save Link As,” but codechef explains the goal is consistent behavior across file types in meeting summaries. A workaround proposed by codechef — using /uploads/default/{UUID} — is warned by sam to be risky, as orphaned uploads may be auto-deleted. sam offers a safer alternative: upload the image normally in a staff-only topic or PM to preserve it. Devansh_Khetan later shares a simpler solution: reducing max image dimensions (e.g., 250x250px) causes larger images to appear as expandable attachments with built-in download buttons. codechef thanks the team for their help and considers the workarounds.
Sure - just change the markdown generated by the upload as per below:
Original is:
resuliting in:
Option 1 is:
[worksonmymachine.png](upload://wD4QT0WxzqkxFMKMI8QRQoRCcWC.png)
EDIT: oops - that one doesn’t actually work… need to specify the full path:
[worksonmymachine.png](//cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/meta/original/3X/e/4/e4b06ce98ded89163747305342cf0074d4260202.png)
Option 2 makes it look like a usual “attachment” upload:
<a class="attachment" href="//cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/meta/original/3X/e/4/e4b06ce98ded89163747305342cf0074d4260202.png">womm.png</a> (31443 Bytes)
resulting in:
A left-click will still view the image. I don’t believe you can force a user to download the file; that’s controlled by the Content-Disposition header sent by the server.
Note that this is a very hacky “solution”, it might sort of work as a quick fix but I’m not sure I would recommend it as a general practice.
Option 1 was my first attempt, then I fell back to your EDIT ![]()
Were you able to identify the full url before posting? I’m trying to come up with something that doesn’t require the user to “inspect” the image url in the preview…
Why don’t you construct the links in angle brackets?
https://global.discourse-cdn.com/meta/original/3X/e/3/e3a33e7186437ab72d2fdcfb5f45c812ae25a571.gif
<https://global.discourse-cdn.com/meta/original/3X/e/3/e3a33e7186437ab72d2fdcfb5f45c812ae25a571.gif>
Right-click, Copy image address?
Did you add the angle brackets as I said?
I know, I know ![]()
The use case is posting items for download as a meeting summary. Those items will sometimes be PDFs, Word docs, slide decks, and images. It would be weird if some some links downloaded and others displayed, right?
If it’s really so necessary, create a new PDF with the image in it? This is a trivial operation in Word, new doc, paste image, save as PDF.
Okay, I have a handful of workarounds to consider. I really appreciate you guys’ help working through this. Thanks for the quick responses. You guys rock @codinghorror and @supermathie!
@codinghorror how dangerous is this? I found a solution that works locally, but may not work for CDN scenarios…
- Copy the image url from the preview window
- Get just the UUID portion
- Hack the link to be /uploads/default/{UUID}
For example:
[Cool image to download](/uploads/default/a099b7b187922f26fbebbbb47807fc83da11fc55)
One a scale of 1 to close your computer and go home for the weekend, how dangerous is this?
@sam says it’ll get deleted by the automatic unreferenced image tombstoning task, so.. as predicted.. bad idea.
As an admin the hack @supermathie suggested will work if you also upload the image totally normally on a different staff only topic. Or in a PM to yourself. That way it will not be deleted.
Is the task looking for the upload:// link in posts?
no it looks for actual images which are linked uploads to the post. I do am no 10000% certain but I don’t think we track an association for A HREF to upload, but maybe I am wrong need to review the code.
Ho una soluzione semplice per questo.
Basta ridurre la larghezza e l’altezza massima delle immagini con un valore piccolo, ad esempio 250px x 250px.
In questo modo, tutte le immagini più grandi di queste dimensioni verranno inviate come allegati: potrai espanderle e si aprirà una scheda con l’opzione di download.
Immagini di riferimento:
