meglio
(Anton)
2016 年2 月 14 日 13:20
1
It’s a strange case.
A use can login and view categories list, but once they click on a topic, it won’t load, and JS debugger reveals the following error:
I got their username / password and experienced the same issue after logging in.
Don’t even know what the reason can be for such behaviour.
meglio
(Anton)
2016 年2 月 14 日 13:22
I also tried to log in from admin panel, but the issue persists.
fefrei
(Felix Freiberger)
2016 年2 月 14 日 13:23
3
Do log entries appear in /logs when you try to log in as him?
meglio
(Anton)
2016 年2 月 14 日 13:26
4
fefrei
(Felix Freiberger)
2016 年2 月 14 日 13:29
5
Only you can see the log entry behind that link (although I want to change that ) – can you paste the data here (possibly cleaning up sensitive pieces)?
meglio
(Anton)
2016 年2 月 14 日 13:31
6
Okay, I now have reproduction steps .
Set user’s website field to http:// - this is by default for many existing users even though you cannot set it to http:// and Save anymore.
Log in as the user and you won’t be able to open any topic.
2 个赞
meglio
(Anton)
2016 年2 月 14 日 13:36
7
ActiveRecord::RecordInvalid (Ошибка валидации: Website неверный) /var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/validations.rb:79:in `raise_record_invalid’
Backtrace
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/validations.rb:79:in `raise_record_invalid'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/validations.rb:43:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/attribute_methods/dirty.rb:29:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:291:in `block in save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:351:in `block in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:211:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:220:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:348:in `with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:291:in `save!'
/var/www/discourse/lib/promotion.rb:72:in `block in change_trust_level!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/transaction.rb:184:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:277:in `transaction'
/var/www/discourse/lib/promotion.rb:61:in `change_trust_level!'
/var/www/discourse/lib/promotion.rb:32:in `review_tl1'
/var/www/discourse/lib/promotion.rb:22:in `review'
/var/www/discourse/app/controllers/topics_controller.rb:520:in `consider_user_for_promotion'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:432:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:145:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:145:in `block in halting_and_conditional'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:504:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:504:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:504:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionview-4.2.5.1/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.8/lib/mini_profiler/profiling_methods.rb:77:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:74:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:43:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/routing/route_set.rb:815:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.3.1/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.3.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/conditionalget.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:129:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5.1/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-1.0.1/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.1/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:10:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5.1/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.8/lib/mini_profiler/profiler.rb:170:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/message_bus-2.0.0.beta.2/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.1/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.1/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5.1/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/lib/unicorn/http_server.rb:562:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/lib/unicorn/http_server.rb:658:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/lib/unicorn/http_server.rb:508:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/lib/unicorn/http_server.rb:132:in `start'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-5.0.1/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `<main>'
cpradio
(cpradio)
2016 年2 月 14 日 14:22
8
I thought there was a migration step added to remove http:// from the website field…
Just checked, there definitely is
committed 09:30PM - 06 Feb 16 UTC
Have you upgraded recently?
1 个赞
meglio
(Anton)
2016 年2 月 14 日 14:32
9
I’m currently at v1.5.0.beta10 +14
Not fresh enough?
cpradio
(cpradio)
2016 年2 月 14 日 14:36
10
Yeah, not fresh enough. The +14 only takes you to February 5th, the migration was added on February 6th.
meglio
(Anton)
2016 年2 月 14 日 14:37
11
Is it safe to upgrade to a non-tagged version?
cpradio
(cpradio)
2016 年2 月 14 日 14:39
12
Yes. There to my knowledge, hasn’t been any regressions noted. Plus that migration is sort of important for your setup right now. So I’d encourage you to upgrade.
2 个赞
cpradio
(cpradio)
2016 年2 月 14 日 14:40
13
Actually one more thing @meglio , this will come in play once you upgrade to latest
Okay, I’m not sure when this started, but I’ve seen it happen multiple times now.
Clicking your avatar clears like notifications even if you don’t view the post.
Repro steps:
Have a like notification appear
Click avatar
Notice highlighted items
Wait a second or two, highlighted like items automatically are now not highlighted (not expected)
Notification Bubble is now gone (expected)
Expected:
Highlighted like notifications should remain highlighted until clicked or the post is viewed (not …
So you may want to take that into consideration
2 个赞
