Gebruikers willen meer dan drie leestekens achter elkaar plaatsen in de body
couldn’t find a similar topic
i’ve looked through every setting and nothing stands out
Hi Jason. :slight_smile:
You can disable the site setting enable markdown typographer, but it will disable other things as well, as per the description:
Use typography rules to improve readability of text: replace straight quotes ' with curly quotes ’, (c) (tm) with symbols, -- with emdash –, etc
This setting will convert two or more consecutive dots into a … character.
Alternatively, without disabling this setting, you can circumvent this behavior by putting a backslash \ in front of the dots to escape the formatting, though it’s not very convenient for this:
will render as:
I hope this helps :slight_smile:
