VPS מארח דיון תקוע בטעינת דפים עם ספינר
סיכום מבוסס בינה מלאכותית
urbancamo reports that their Discourse site, hosted on a VPS, has suddenly stopped working properly. The banner and topic list load, but clicking on a topic gets stuck at the spinner. Despite restarting and rebuilding Discourse, the issue persists.
itsbhanusharma suggests that the problem might be due to a server misconfiguration, specifically with HTTPS connections. urbancamo explains that the VPS uses a separate SSL gateway and that recent DNS hosting changes might be the cause.
itsbhanusharma advises that Discourse can generate its own SSL certificates using Let’s Encrypt, making manual configuration unnecessary.
Hi, I’ve been using discourse for over a year now on our Wainwrights on the Air site. It has been working beautifully, but then a couple of days ago it stopped working - the banner loads and a list of topics load but if you try and drill down into a post it just gets stuck at the spinner.
Eg: https://discourse.wota.xyz/t/some-old-photos-that-i-have-been-scanning/183/5
I have tried restarting discourse, and rebuilding discourse, but these have not fixed the issue.
Any clues to what might be the issue please?
Thanks, Mark
Your site https://discourse.wota.xyz/ seems to be unreachable over HTTPS. something is blocking connections to the secure version of your site and I’d blame a server misconfiguration. Have you disabled https for your site?
Hi Bhanu - thank you for the reply. I was confused as to why some content loads, and other content doesn’t.
The OVH VPS that is hosting this discourse site uses a separate SSL gateway, and the DNS hosting has changed recently, so I will update the DNS record to point to the SSL gateway, and hopefully that will resolve the issue.
Thanks, Mark.
You really don’t need to configure all that as long as you point your subdomain to your VPS and let discourse generate SSL for itself. DIscourse comes with built in support for free SSL from letsencrypt so you really don’t have to configure anything unless you want to.
