אזהרה: יציאה 443 של המחשב אינה נגישה באמצעות שם המחשב בשרת שהוגדר לאחרונה
סיכום מבוסס בינה מלאכותית
Kushalghosh9899 encountered a port 443 accessibility issue on a new AWS Lightsail server while installing Discourse, despite enabling the port via ufw. itsbhanusharma correctly pointed out that AWS Security Groups must also allow port 443, which resolved the first issue. Following installation, Kushalghosh9899 faced a new problem: admin confirmation emails weren’t being sent. They had configured AWS SES with SMTP credentials and opened port 25, but emails still failed. itsbhanusharma explained that AWS SES must exit sandbox mode to send emails, linking to AWS documentation. Although Kushalghosh9899 successfully exited sandbox mode, emails still didn’t send. Running ./discourse-doctor revealed an SMTP-related error. Ultimately, Kushalghosh9899 resolved the issue by changing the SMTP server/endpoint configuration. The thread highlights common AWS SES pitfalls during Discourse setup: Security Group misconfigurations, sandbox restrictions, and incorrect SMTP endpoint settings.
WARNING: Port 443 of computer does not appear to be accessible using hostname: team.krsh.org.
I have followed all the steps in AWS lightsail with 2gb ram and 1cpu core, tried ‘sudo ufw allow 443/tcp command’ too, but it wasn’t working.
Kindly help me to fix this issue as this is a new machine and nothing was configured I have started fresh.
Thank you.
this 443 is enabled but still it is giving error
If this is AWS, You need to enable those ports in your Security Group.
yes, it worked thank you.
Now there is a new problem arising after post installation when I am trying to complete the registration process i.e., registration admin email is not coming
so I have opened 25 port number in the security group in AWS because during installation I have used this port, but still mail is not coming.
I guess problem is with smtp server address, can you help me out with that from where to get smtp server address for AWS EC2 instance as I am using AWS SES mail and I have created SMTP credentials too and I am using these details only but I am not sure about the smtp server address.
Kindly help me out with this.
Thank you.
I have added smtp endpoint as a smtp server address and opened smtp port number 25 from the aws security group still confirmation emails are not coming.
Kindly help me out.
What email provider are you using to send emails? If it is SES then you need to be out of sandbox before you can send emails.
yes, I am using SES only.
Kindly explain how to these settings, it would be really great for me as I need to complete it asap.
Hey, tried moving out AWS SES out from the sandbox and the verification is completed but still not being able to send the emails.
Any other possible reasons for this email error and how to debug this kindly let me know.
executed ./discourse-doctor and got this error while sending the mail
This issue is being solved by changing the SMTP endpoint/server.
