Not sure what happened. I have this plugin disabled. Do you know why this is?
He’s been fine, but just now I downloaded a discoursehub app. after logging in once, I uninstalled it after realizing that I was still viewing the forums using the mobile browser app. Right after I connected with this app, I lost this plugin.
Even after I installed this plugin again.
I had this feature before.
It originally looked like this. Now it’s gone.
If you log out does it appear?
As you may have guessed. I logged out and logged back in. That is, is this due to my personal account? And how should I set it up?
If you look at the OP of this topic and the theme component’s settings, you will see that the banner can be dismissed as an option. Assuming the option to dismiss is enabled, you should be able to disable it. There are other settings you may want to look at regarding hiding for staff and mobile:
when it is 5,it’s ok~!
oh yea always test with test user accounts of lower trust level too. I have test user accounts for each level and group. glad you got it figured out ![]()
thank you very much!!
And I thought I was covering this well with my two test users! Lilly, you are a machine (in a good way)!
This saved me - trust 5 - thank you much!
