since I’ve decided to run my discourse in the old way,I upgrade the source to the latest version,and it require ruby with version 1.9.3 above,so I switched to using rvm and followed this guideenter link description here
Everything seems go fine but only "502 Bad Gateway"error appears when I tried to visit my forum.So what should I check?Thanks a lot.
Continuing the discussion from Trouble with installing docker :
I’m using linode box with Ubuntu13.04,when I tried to install docker, appears the following erros:
root@bbs:/home/dushu# sudo apt-get install lxc-docker --fix-missing
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following package was automatically installed and is no longer required:
ruby-dev
Use ‘apt-get autoremove’ to remove it.
The following extra packages will be installed:
aufs-tools cgroup-lite lxc-docker-1.1.2
The following NEW packages will be installed:
aufs-tools cgroup-lite lxc-docker lxc-docker-1.1.2
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 91.8 kB/4,524 kB of archives.
After this operation, 18.1 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
WARNING: The following packages cannot be authenticated!
Install these packages without verification [y/N]? y
Err Index of /ubuntu raring/universe aufs-tools amd64 1:3.0+20120411-3ubuntu1
404 Not Found [IP: 2001:67c:1562::13 80]
Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/universe/a/aufs-tools/aufs-tools_3.0+20120411-3ubuntu1_amd64.deb 404 Not Found [IP: 2001:67c:1562::13 80]
Unable to correct missing packages.
E: Aborting install.
Has anybody seen this before,any suggestion will be grateful.
lake54
(James Milligan)
August 3, 2014, 5:00pm
Unless you need to use 1.9.3 for something else, try using Ruby 2.0.0. Also, this guide still works as of the other day, so maybe give that a shot? https://github.com/discourse/discourse/blob/master/docs/INSTALL-ubuntu.md
We regret that we can only support the Docker based installs here. Sorry.
