Não é possível instalar o Discourse: módulo aufs não encontrado
When i do wget -qO- https://get.docker.com/ | sh
The very next line says modprobe: FATAL: Module aufs not found.
But the installation continues, but after doing “./launcher bootstrap app” and “./launcher start app” i get fatal errors.
I am following the OFFICIAL install guide steps on a standard ubuntu 14.04 LTS. Whatsup?
(PS - my email SMTP credentials are correct)
Docker is not installing properly. Until docker is installed properly nothing will work.
…how can i install it properly?
PS: What’s your vps provider?
this one is on OVH.
I don’t understand, if it is a standard Ubuntu 14.04 LTS, what could be different?
OK…
This is the 4th time i tried to install, after trying the “fix” in the thread provided by @Falco which is
sudo apt-get install lxc wget bsdtar curl
sudo apt-get install linux-image-extra-$(uname -r)
sudo modprobe aufs
I still get the error:
FAILED
RuntimeError: /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end' failed with return #<Process::Status: pid 219 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params "/usr/local/bin/ruby -e 'if ENV[\"DISCOURSE_HOSTNAME\"] == \"discourse.example.com\"; puts \"Aborting! Domain is not configured!\"; exit 1; end'"
d0ee9b65b9f5191547ee326f11251162835f0dc68446622349ccae6cf07bb214
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
It says the domain is not configured in the error you posted. Make sure docker info shows aufs as the filesystem and docker version is correct.
docker info
Containers: 0
 Running: 0
 Paused: 0
 Stopped: 0
Images: 1
Server Version: 1.11.0
Storage Driver: aufs
 Root Dir: /var/lib/docker/aufs
 Backing Filesystem: extfs
 Dirs: 6
 Dirperm1 Supported: false
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
 Volume: local
 Network: null host bridge
Kernel Version: 3.13.0-55-generic
Operating System: Ubuntu 14.04.4 LTS
OSType: linux
Architecture: x86_64
CPUs: 1
Total Memory: 1.908 GiB
Docker Root Dir: /var/lib/docker
Debug mode (client): false
Debug mode (server): false
Registry: https://index.docker.io/v1/
WARNING: No swap limit support
docker version
 Client:
 Version:      1.11.0
 API version:  1.23
 Go version:   go1.5.4
 Git commit:   4dc5990
 Built:        Wed Apr 13 18:34:23 2016
 OS/Arch:      linux/amd64
Server:
 Version:      1.11.0
 API version:  1.23
 Go version:   go1.5.4
 Git commit:   4dc5990
That looks fine now. Read the error. Your domain is not configured in app.yml
When i do a nano containers/app.yml , it opens a new file now? Wut? What is this now? — this was my stupidity.
Here is my domain in my app.yml
DISCOURSE_HOSTNAME: 'discourse.example.com'
You are expected to change example.com to the domain you bought.
The instruction —
Set DISCOURSE_HOSTNAME to discourse.example.com, this means you want your Discourse available at http://discourse.example.com/. You’ll need to update the DNS A record for this domain with the IP address of your server.
I really think that you should specify it more clearly there.
And i changed discourse.example.com to mydomain.com, not just example.com …
It is working fine now…
Thanks.
For the record, you automatically get a domain like vps12345678.ovh.net with all OVH VPSs, it turned out to be useful for testing.
