This just popped into my feed in twitter (retweeded by codinghorror I believe). Not sure if it should be better displayed on discourse?
This is how it should look:
Win 7 here on this machine probably explains it then. Thanks.
Installing the latest version of Symbola is all that is needed under Linux:
http://users.teilar.gr/~g1951d/
(Typically Linux fonts can be installed in a lot of locations, but ~/.fonts/ is easiest.)
Symbola is a ttf format font, and should work under Windows, too.
Checked in on my Ubuntu machine and works as is. Can be closed.
We could pass the oneboxer html through the emoji remapper.
