כפתור הערת שוליים במלחין
סיכום מבוסס בינה מלאכותית
The Composer Footnote Button theme component, created by Don, adds an Insert Footnote button to the composer when used with the Discourse Footnote plugin. The component has settings to customize the button’s icon, placement, and text. However, as noted by nathank, it only provides the button and not the footnote functionality. denvergeeks reported an error with the component, but Don was unable to replicate it. The component is now obsolete, as announced by Don, since the footnote button is available in core.
Hello :wave:
This theme component is to be used with Discourse Footnote plugin and it’s add an Insert Footnote button to composer.
There are a few settings:
By default:
  • it uses superscript icon what you can change with composer footnote button icon setting.
  • it shows on popup options menu in composer uncheck the put in popup menu setting to show it on toolbar section.
If you uncheck the put in popup menu setting than you can select from 3 groups to where you want to place this button on toolbar.
Default: insertions
  • insertions
    Screenshot 2022-11-01 at 1.08.12
  • fontStyles
    Screenshot 2022-11-01 at 1.09.15
  • extras
    Screenshot 2022-11-01 at 1.10.19
Clicking on the footnote button will insert the code. This text you can change with composer footnote button text translation.
^[This text will be in footnote]
Theme Translations:
9 לייקים
It isn’t super clear that this component only provides the button and not the functionality of the footnote plugin (the only real clue is the tag on the topic).
Why isn’t this functionality rolled into the official plugin anyway? It would be a very useful addition!
6 לייקים
Thanks @nathank :slightly_smiling_face: I forget to add this important info. I updated the OP.
5 לייקים
Hi @Don! There appears to be an error with this theme component…
… which it seems might be resolved as advised here…
2 לייקים
Hmm… :thinking: I checked this and I didn’t get this error. I think it is probably depends on the other components. I will try to figure out and maybe modify it with the api.
3 לייקים
Hello :waving_hand: This is now found in core, so you don’t have to use this to have a footnote button. I’ve added the end-of-life tag.
5 לייקים
