The issue involves a missing subcategory dropdown on the category edit page in Discourse. Moin reports that when editing a category, the dropdown to navigate to its subcategories does not appear, even though it works after a page reload. RGJ confirms this is a broader issue where category changes require a full reload to take effect. Moin clarifies that the problem occurs specifically when navigating to a subcategory of the currently edited category, not when the subcategory has a different parent. Lilly confirms the bug and thanks Moin for the report. j.jaffeux initially misunderstands the issue but later acknowledges the bug after clarification. Moin notes the issue became more noticeable after creating a new category. The problem is tied to the UI not updating dynamically when navigating between categories.
When are at the page where you can edit a category and use the dropdown at the top to navigate to a subcategory of that category, the dropdown for subcategories does not appear.
In the video, I start at the test-3 category, which is the parent category of test-category. Then I use the dropdown to navigate to the edit page of test-category.
This is a generic issue. Any changes to categories need a full reload to be into effect. Same goes for creating a category and then trying to create a post in it, or to assign a group to it. It would be great if the system would just issue a reload via the MessageBus if only for the user making the edit.
Could you explain which changes you mean? I didn’t edit anything. This problem only occurs if the subcategory I choose is a subcategory of the category I am looking at. If the subcategory has a different parent category, it works fine.
For example, switching from test-3 to Status, a subcategory of Team, works fine.
yea I can totally repro this - sorry Moin, I hadn’t seen this topic yet. I was like where is the missing subcategory dropdown, and I was just about to post a note about it. thanks for the heads up
I think you need to start at “General”, use the wrench, and then use the dropdown at the top to navigate to “Test”.
Then the subcategory dropdown does not appear and is also missing when you go back
I noticed the bug some time ago, but it became more annoying after I created Related category permissions because then I navigated to the subcategory more frequently.
