使用 JS API
Discourse 的 JavaScript API 允许主题和插件对用户体验进行广泛的自定义。最简单的使用方式是:在管理面板中创建一个新主题,点击“编辑代码”,然后切换到 JS 选项卡。
对于基于文件的主题,可以通过在 api-initializers 目录中创建一个文件来使用该 API。对于主题,路径为 {theme}/javascripts/api-initializers/init-theme.gjs;对于插件,路径为 {plugin}/assets/javascripts/discourse/api-initializers/init-plugin.js。文件内容应为:
export default apiInitializer((api) => {
  // 在此处编写你的代码
所有可用的 API 均列在 Discourse 核心库的 plugin-api.gjs 源代码 中,并附有简短描述和示例。
如需查看包含 JS API 使用示例的完整教程,请访问:
本文档受版本控制 - 如需提出修改建议,请前往 GitHub
39 個讚
What’s the best way to “import” as a Site Customisation? - is it just to use require?
Whilst this works:
<script type="text/discourse-plugin" version="0.1">
var HamburgerMenuComponent = require('discourse/components/hamburger-menu').default;
</script>
This does not:
import {default as HamburgerMenuComponent2 } from 'discourse/components/hamburger-menu';
</script>
Where I get this error:
<script type="text/discourse-js-error">unknown: 'import' and 'export' may only appear at the top level (3:0)
  1 | Discourse._registerPluginCode('0.1', api => {
  2 |
> 3 | import {default as HamburgerMenuComponent2 } from 'discourse/components/hamburger-menu';
  4 |
  5 |
  6 | }); at <eval>:8695:14</script>
2 個讚
Instead of importing it, you can look it up with
api.container.lookupFactory('component:hamburger-menu')
5 個讚
Is there a way to get access to the h helper from virtual-dom in a site customization? I’m trying to add a simple dropdown widget to use in our header, and I can’t get that darned h, even though I can get createWidget
Does:
h = require('virtual-dom').h;
not work?
2 個讚
Yes it does! Works perfectly, thanks a ton!
I wouldn’t recommend doing it that way as it would likely break future compatibility. You can use this for now but I’ll try to introduce a workaround shortly that will be safer long term.
5 個讚
Makes sense, it’s kinda circumventing the whole Plugin API thing and relying on implementation details of the ES6 compilation output, both things that are Dangerous™
Anyways, I’ll definitely keep an eye out for a better solution
I’ll try to get to it soon and I’ll reply in this topic, so watch it and you’ll see :slight_smile:
4 個讚
Actually thinking about it, the decorateWidget helper gets called with an object that has the h method. How are you inserting your widget if not via a decorator?
If you could post code that would be helpful.
{{mount-widget}} in a template for a plugin outlet.
1 個讚
Ah that’s clever – I didn’t think people would try that. Okay, let me try something out.
Okay, I’ve added h to the pluginApi object as long as you request plugin api v0.3:
<script type="text/discourse-plugin" version="0.3">
  console.log(api.h('b', ['hello', 'world']));
</script>
That should work for you!
https://github.com/discourse/discourse/commit/b10b6c673d5f4936d0ee107e16531df106fae75e
9 個讚
此功能已弃用,截至:
1 個讚
已在此处以及许多其他版本控制文档中更新。感谢您的提醒 @NateDhaliwal
2 個讚
此链接不再有效,我收到此消息:
discourse 的 main 分支不包含路径 app/assets/javascripts/discourse/app/lib/plugin-api.gjs。
2 個讚
Ah,这是因为 javascript 文件被移动到了 frontend/ 目录,而不是 app/assets/javascripts/。\n\n我已经打开了一个 PR:\nChange app/assets/javascripts/ to frontend/ by NateDhaliwal · Pull Request #75 · discourse/discourse-developer-docs · GitHub
5 個讚
顶一下这个拉取请求(PR)。可以进行审查了吗?谢谢!
1 個讚
已于十二月合并。:tada:
1 個讚
