Documentation about extending Discourse with plugins, themes, and theme components, working with the core code, and using the Discourse API.
Introduction
- Introduction: Introduction to Discourse Development
Development Environments
- Dev Container: Developing Discourse using a Dev Container
- GitHub Codespaces: Developing Discourse on GitHub Codespaces
- Docker setup: Install Discourse for development using Docker
- macOS setup: Install Discourse on macOS for development
- Ubuntu/Debian setup: Install Discourse on Ubuntu or Debian for Development
- Windows setup: Install Discourse on Windows for development
- Non-Docker plugins: Install plugins in your non-Docker development environment
- Local setup: Set up a local Discourse Development Environment?
- Multisite setup: Set up a multisite development environment
- Fedora setup: Set up Discourse for development on Fedora Linux
Code & Internals
- Ember components: Add Ember Components to Discourse
- UI kit: The UI kit of shared Discourse components, helpers, and modifiers
- Lint and format: Automatically lint and format code before commits
- Acceptance tests: Write acceptance tests and component tests for Ember code in Discourse
- Run test suites: How to run Discourse core, plugin and theme QUnit test suites
- Version compatibility: Pinning plugin and theme versions for older Discourse installs (d-compat branches)
- Ember object ownership: Ember object ownership (getOwner, service injections, etc.)
- JS performance: Using Googleās ātachometerā to measure JS performance changes in Discourse
- CI with GitHub Actions: Setup Continuous Integration using GitHub Actions
- Markdown extensions: Developerās guide to Markdown extensions
- Converting modals: Converting modals from legacy controllers to new DModal component API
- DModal API: Using the DModal API to render Modal windows (aka popups/dialogs) in Discourse
- JS API: Using the JS API
- Plugin outlet connectors: Using Plugin Outlet Connectors from a Theme or Plugin
- modifyClass: Using modifyClass to change core behavior
- Creating routes: Creating Routes in Discourse and Showing Data
- Authentication method: Adding a new āmanagedā authentication method to Discourse
- Accidental serialization of ActiveRecord models: Preventing accidental serialization of ActiveRecord models
- Overriding templates: (not recommended) Overriding Discourse templates from a Theme or Plugin
- Service objects: Using service objects in Discourse
- System specs: Write end-to-end system specs for the Discourse user interface
- FormKit: Discourse toolkit to render forms.
- AppEvents Triggers: AppEvents Triggers Reference
- Transformers: Using Transformers to customize client-side values and behavior
- Topic List Customization: Customizing the topic list
- CSS guidelines: Guidelines for CSS classes using BEM
- JS type hinting & validation: JavaScript type hinting & validation (typescript)
- Designing for Devices: Designing for Different Devices (Touch & Hover)
- Designing for Responsive Widths: Designing for Responsive Widths (Breakpoints, Viewport & Containers)
- Gesture primitives: Drag, resize, and gesture primitives
- Bundle splitting: Bundle splitting for plugins
- Private modules: Private modules and the
-internalsconvention
Plugins
- Basic plugin: Developing Discourse Plugins - Part 1 - Create a basic plugin
- Plugin outlet: Developing Discourse Plugins - Part 2 - Connect to a plugin outlet
- Site settings: Developing Discourse Plugins - Part 3 - Add custom site settings
- Git setup: Developing Discourse Plugins - Part 4 - Setup git
- Admin interface: Developing Discourse Plugins - Part 5 - Add an admin interface
- Acceptance tests: Developing Discourse Plugins - Part 6 - Add acceptance tests
- Publish your plugin: Developing Discourse Plugins - Part 7 - Publish your plugin
- New locales: Add a new locale from plugin
- Chat integration: Add a new provider to discourse-chat-integration
- markdown-it extension: Repackaging a markdown-it extension as a Discourse plugin
- Rails autoloading: Structuring a plugin for Rails autoloading
Themes & Components
- Developing Themes: Developing Discourse Themes & Theme Components
- Quick reference: Theme Developer Quick Reference Guide
- Designers guide: Designerās Guide to getting started with themes in Discourse
- Theme Creator: Get started with Theme Creator and the Theme CLI
- Theme CLI: Install the Discourse Theme CLI console app to help you build themes
- Theme structure: Structure of themes and theme components
- Multiple JS files: Split up theme Javascript into multiple files
- Multiple SCSS files: Split up theme SCSS into multiple files
- Theme settings: Add settings to your Discourse theme
- Objects for theme settings: Objects type for theme setting
- Migrate settings: Migrate Discourse theme settings
- Theme metadata: Adding metadata and screenshots to a Theme
- Core variables: Use Discourse Core Variables in your Theme
- Localizable strings: Add localizable strings to themes and theme components
- E2E testing: End-to-end system testing for themes and theme components
- Minimizing maintenance: Minimizing Maintenance on Theme Customizations
- Font sizes: Change font sizes in your themes
- Include assets: Include assets (e.g. images, fonts) in themes and components
- Custom icons: Replace Discourseās default SVG icons with custom icons in a theme
- Dark mode: Update themes and plugins to support automatic dark mode
- Theme modifiers: Theme modifiers: A brief introduction
- Pseudo-elements: Insert text or images anywhere on your site using CSS pseudo-elements
- Font component: Create and share a font theme component
- Highlight.JS language: Install a new language for Highlight.JS via a theme component
- Homepage content: Add custom content that only appears on your homepage
- Message format: Message Format support for localization
- Global icon changes: Change icons globally
- Alternative icons: Alternative icons
- Wiki post style: Change the style of a wiki post
- Color scheme: Create and share a color scheme
- Navigation menu: Use the
navigation_menuquery parameter to preview the sidebar or other options - Post content styles: Customize postsā contents with your own styles
- Theme screenshots: Adding preview screenshots to Discourse themes
- Themeable site settings: Controlling site settings with themes
General Guides
- White-labelling mobile apps: Things to consider before deciding to white-label the Discourse Mobile apps
- Custom automations: Create custom Automations
- Public data dump: Discourse Public Data Dump
- AI evals: Run Discourse AI evals
- AI bot via API: Using the AI bot via the Discourse API
Theme Dev Tutorial
- 1 - Introduction: Theme Developer Tutorial: 1. Introduction
- 2 - Remote Theme: Theme Developer Tutorial: 2. Creating a remote theme
- 3 - CSS: Theme Developer Tutorial: 3. CSS in Themes
- 4 - Outlets: Theme Developer Tutorial: 4. Using Outlets to insert and replace content
- 5 - Components: Theme Developer Tutorial: 5. Building and using components
- 6 - JS API: Theme Developer Tutorial: 6. Using the JS API
- 7 - Conclusion: Theme Developer Tutorial: 7. Wrapping up
