Anpassung von Discobot für Ihre Seite
:bookmark: This guide explains how to customize Discobot, the built-in assistant bot in Discourse, to better match your community’s persona and needs.
:person_raising_hand: Required user level: Administrator
Discobot is a special user in your Discourse community that helps new members learn about the platform. As an administrator, you can customize various aspects of Discobot to better fit your community’s style and requirements.
Modifying Discobot’s user profile
To customize Discobot’s profile:
  1. Go to Admin > Users and select the Discobot user.
  2. Select “Preferences” or click “Visit this user’s preferences page to edit their profile”:
Once in the Preferences section, you can modify the following settings:
Account settings
  • Name: Click the “Edit” button to change Discobot’s name.
  • Image: Click the “Edit” button to upload a new avatar image.
  • After making changes, click the “Save Changes” button.
Profile settings
Customize Discobot’s profile information as needed.
Email settings
Adjust email-related settings as needed.
Updating Discobot’s welcome message
To change the welcome message sent by Discobot:
  1. Go to Discobot’s profile (https://example.discourse.com/u/discobot/summary) and select “Messages”.
  2. Click on “Sent”.
  3. Find a greeting message that you want to modify.
  4. Copy a unique part of the message, such as “I’m only a robot”.
  5. Navigate to the Admin Interface (https://example.discourse.com/admin)
  6. Go to Appearance > Site Texts (https://example.discourse.com/admin/customize/site_texts)
  7. Paste the copied text into the search window. When the greeting message appears, click “Edit”.
  8. Update the greeting message and click “Save Changes”.
Limitations and additional information
  • You can reuse existing variables in messages (like %{title}), but you cannot add new ones.
  • Discobot must remain an administrator; this role cannot be removed.
For further customization needs or feature requests, consider posting in the Feature category.
38 „Gefällt mir“
Is it possible to make a new conversation discobot with With members and make a new certificate for them ?
I am admin to an educational forum and I want to make a new conversation with a new certificate :slight_smile:
3 „Gefällt mir“
No, you cannot currently customise the full experience.
3 „Gefällt mir“
Is it possible to know the codes for messages such as %{title}
Excuse me for my many questions :slight_smile:
Questions are fine. :slight_smile:
You can reuse any existing variables in the message but you cannot add new ones.
5 „Gefällt mir“
many thanks @HAWK
Is it possible to define the existing variables if possible? :slight_smile:
1 „Gefällt mir“
I suggest adding that either
  1. People need to update the Discobot’s profile About me because it’ll still say message or mention @discobot even after you change its name
or
  1. Maybe Discourse could remove the username from the default message? I went ahead and edited our About me to just say
Hi, I’m not a real person. I’m a bot that can teach you about this site. To interact with me, send me a message or mention me anywhere.
Just in case we have to change it again, we don’t need to remember to also change the About me.
4 „Gefällt mir“
Is this something that’s going to be possible in the future? The current question/answer format of fortune and quote is sufficient for what I have in mind.
1 „Gefällt mir“
@codinghorror is extending the discobot functionality on our roadmap at all?
2 „Gefällt mir“
That’s a good point we should make that copyedit, @tshenry can you take it? No need to deal with it retroactively just for new ones. Say “mention me by name” so editing the name doesn’t require editing the “about me”.
@hawk we don’t plan on extending discobot at the moment.
7 „Gefällt mir“
Should be done with the following!
https://github.com/discourse/discourse/pull/11820
8 „Gefällt mir“
Does Discobot have to be a Moderator or can I take this role away from him? I mean, will he still work then?
2 „Gefällt mir“
As far as I can tell from looking at the code and the UI, Discobot should never be able to become a moderator.
If you meant an admin, then no, unfortunately there is no way to take the admin role away from DIscobot at this time.
7 „Gefällt mir“
Danke für die Antwort. Ist es seit den letzten Beiträgen möglich, das Discobot-Benutzertraining und das Training für fortgeschrittene Benutzer anzupassen, oder ist dies immer noch Standard? Wir erhalten viel Suchverkehr mit dem Wort „Capybara“, möchten aber vielleicht einen anderen Begriff ausprobieren?
1 „Gefällt mir“
Tatsächlich glaube ich, dass sich das, worauf ich mich beziehe, hier befinden könnte: Customizing Discobot for your site - #7
2 „Gefällt mir“
Gibt es eine Möglichkeit, wie ein Administrator einen bestimmten Teil des Tutorials ein- oder ausschalten kann?
Zum Beispiel erfordert das Flag-Tutorial, dass der Benutzer das Flag “Unangemessen” auswählt. Dieses Flag ist in unserer Instanz ausgeblendet, da es nicht zu unserem Anwendungsfall passt. Folglich können unsere Benutzer das Tutorial nicht abschließen. Wenn ich nur diesen einen Abschnitt deaktivieren/überspringen könnte, könnten wir das Tutorial wieder aktivieren.
2 „Gefällt mir“
Sie könnten die Anweisungen für den Schritt ändern, ähnlich wie das Liken eines Beitrags übersprungen werden kann, wenn Likes deaktiviert sind. Likes deaktivieren – Discobot-Tutorial aktualisieren
3 „Gefällt mir“
Sie können keine Schritte entfernen oder hinzufügen, aber Sie können den Inhalt der vorhandenen Schritte anpassen (nicht jedoch die Trigger).
4 „Gefällt mir“
Würde das gerne betreuen und es darauf trainieren, Fragen zum Hauptthema des Forums mithilfe von LM / ChatGPT usw. zu beantworten… möglich?
Es ist am besten, Ihre eigene KI-Persona/Bot zu erstellen, anstatt zu versuchen, Discobot anzupassen.
1 „Gefällt mir“
