Цветной текст в Discourse
“BBCode-lite” without the need to install a plugin …
Adds a simple control (palette icon) to the Composer to facilitate colouring of the foreground and background of text
  • Select a word or text
  • Hit the palette control
  • It will be wrapped like so: [wrap=color color=# bgcolor=#]word[/wrap]
  • Replace the #s with html-compatible colour names, e.g. “red”, “grey” … experiment.
:biohazard: NB Same caveats apply as to BBCode: can be used to hide text.
Credits
18 лайков
Thanks a ton for this useful little component.
It doesn’t seem to be applying the composer.color_ui_button_title properly, both when left at the default or when customized:
Screenshot from 2023-03-19 12-36-30
1 лайк
Hello there. I don t have color text button like on this foto. Here I don t see too.
3cb9195635135aec1a3341f3015258023e5f0386
This Theme component is not installed here. That is why the button does not appear.
Did you add it to your site?
If I knew how to add a plugin it would be good.
I’ve fixed this.
1 лайк
There is a guide how to Install a theme or theme component
All the information is part of the table in the first post
3 лайка
Thanks very much!
1 лайк
Excellent component!
Bug report: If I click the palette button with no text selected, it inserts the translation descriptor instead of the ‘default text’:
[en_GB.composer.color_ui_default_text]
isn’t found in the site text customization menu, and isn’t on the component settings page.
2 лайка
Clicking the palette icon without having text selected output this:
[wrap=color color=# bgcolor=#][en.composer.color_ui_default_text][/wrap]
Is this a missing string?
3 лайка
that’s a nasty issue, fixed:
thanks for the reports @Frully @Canapin
I’ve added settings for default colours.
5 лайков
I didn’t even read the last message :facepalm:
3 лайка
Awesome work @merefield! This has been a sorely missing feature - until now!
I wonder if this could be combined with this TC to have a single super-awesome BBCode TC:
4 лайка
