Instale Discourse no CloudPanel
:warning: This installation method is not officially endorsed. Use at your own risk.
The Discourse team only recommend installation using the official install guide
:information_source: This is an unsupported install, appropriate for those who have experience with CloudPanel, are experienced system administrators, and comfortable with docker, reverse proxies, and have successfully completed a standard installation.
Why CloudPanel
Why might you want to install a Discourse Forum on a VPS or Dedicated Server running CloudPanel?
Here are my reasons:
I prefer to use a graphical interface for server and site administration. I’ve used most of the web hosting control panels at one time or another.
In comparison to the rest, CloudPanel is very slim and minimal and uncluttered. It has every feature I need, presented very simply and intuitively. And that’s it. It has nothing I don’t need.
I develop and host and manage many Ghost blogs, Wordpress sites, Drupal sites, and other types of sites in addition to Discourse forums. I really only need one server where I can host my Discourse forums right along side my Ghost Blogs and my Wordpress and Drupal sites. (I don’t want to pay for and maintain a separate server for each instance of Discourse.)
CloudPanel includes (right out-of-the-box) built-in Nginx and a simple interface for setting up and managing Reverse Proxies which are necessary in order to run one or more instances of Discourse on the same server or with other types of websites.
The Discourse team (and the Meta forum staff here) do not provide support for alternative server environments like Cpanel or Plesk or (as in this case) CloudPanel, or others that rise up out of the command line.
So I thought I’d share my setup and my process in case there are others who might find it useful.
[If anyone tries this method, please do let me know if/how it works out for you, or if I can improve this tutorial! :heart_eyes: ]
Install Docker
In Putty (or other terminal), from the root directory, run
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg
echo "deb [arch=amd64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu focal stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt update
sudo apt-get install docker-ce docker-ce-cli docker-compose containerd.io
Create a Reverse Proxy Site in CloudPanel
→ We click the + Add Site button…
For my Discourse instance I am using my domain name noobish.me, so from now on wherever you see that in the rest of these instructions, replace noobish.me with your actual domain name (for example, yoursite.com)
→ We create a new “Reverse Proxy Site” in the CloudPanel for the domain where we want to host our Discourse forum (of course the DNS A record of the domain needs to be pointing to the same IP address as our CloudPanel.)
Prepare the Domain and Set up SSL
For my site I’m using Cloudflare’s nameservers to point the domain. In Cloudflare I set the SSL to Full or Full (strict).
I also create a Cloudflare Page Rule. Visit this post to learn why.
I’m also using a free Cloudflare SSL Origin Certificate for my domain, which I “Import” into CloudPanel within the “SSL/TLS” site settings for that site (by simply pasting in both the Certificate and the Private Key I had downloaded for that domain name from my Cloudflare account.)
Install Discourse
Back in Putty (or other terminal), from the root directory (c d Enter to get back to the root) → Install the Discourse Standard Install using these commands…
git clone https://github.com/discourse/discourse_docker.git /var/discourse
Enter
cd /var/discourse
Enter
chmod 700 containers
Copy the Standalone Configuration
Now we copy the file /var/discourse/standalone.yml to /var/discourse/containers/ as app.yml before editing it according to our site settings.
cp /var/discourse/samples/standalone.yml /var/discourse/containers/app.yml
Edit the app.yml File
In addition to modifying the app.yml file according to our specific site settings, we need to change 3 more things in that file before we save it…
Under the section templates: we need to add
  - "templates/web.socketed.template.yml"
Because I’m using Cloudflare, under the section templates: I also add
  - "templates/cloudflare.template.yml"
Under the section expose: we need to comment out
  #- "80:80"   # http
  #- "443:443" # https
Under the section env: we need to add
   DISCOURSE_FORCE_HTTPS: true
For reference, you can Click Here to see the contents of my working app.yml on noobish.me where I'm using both Cloudflare and Mailgun...
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
params:
  db_shared_buffers: "4096MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 8
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: 'noobish.me'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'admin@noobish.me'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: postmaster@noobish.me
  DISCOURSE_SMTP_PASSWORD:  pYdRLyQW
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  #DISCOURSE_SMTP_DOMAIN: noobish.me    # (required by some providers)
  DISCOURSE_NOTIFICATION_EMAIL: noreply@noobish.me    # (address to send notifications from)
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP address key for IP address lookup
  ## see https://meta.discourse.org/t/-/137387/23 for details
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
Then we save and exit the app.yml file…
CTRL-X
y
Enter
Next we set the permissions for the app.yml file…
chmod o-rwx containers/app.yml
then…
Bootstrap the App
cd /var/discourse
./launcher bootstrap app
This will take a considerable amount of time. In the end of the bootstrap process, you’ll be asked to:
./launcher start app
Edit the Vhost File
Now we go back into our CloudPanel and paste the below code into the “Vhost Editor” for our Discourse site (overwriting what is already there). Of course replace yoursite.com with your actual domain name.
server {
  listen 443 ssl http2;
  listen [::]:443 ssl http2;
  {{ssl_certificate_key}}
  {{ssl_certificate}}
  server_name yoursite.com;
  {{root}}
  {{nginx_access_log}}
  {{nginx_error_log}}
  if ($scheme != "https") {
    rewrite ^ https://$host$uri permanent;
  location ~ /.well-known {
    auth_basic off;
    allow all;
  {{settings}}
  add_header Cache-Control no-transform;
  location / {
                proxy_pass http://unix:/var/discourse/shared/standalone/nginx.http.sock:;
                proxy_set_header Host $http_host;
                proxy_http_version 1.1;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-Forwarded-Proto $scheme;
                proxy_set_header X-Real-IP $remote_addr;
Restart Nginx
Next we need to restart Nginx, which we can do by clicking a button in the Admin Area of the CloudPanel…
Congratulations!
Now, in our browser, we can go to our site’s URL and run the Discourse Setup Wizard…
Cohabitate Peacefully
Now I can self-host and manage my Discourse site right along side my Ghost, Wordpress, Drupal and other types of sites using a clean and lean management panel, with minimal need going forward to use the terminal/command line.
To Install Additional Discourse Instances…
3 curtidas
Você deve excluir essas etapas e criar o app.yml sem gerar esse erro. É confuso.
(Se você vai substituir o arquivo inteiro, por que copiar o exemplo?) A melhor coisa a fazer é dizer o que precisa ser alterado no exemplo existente. Parece que é o modelo de socket e forçar https.
Isso lhe dá duas cópias do postgres, que usa mais RAM do que um único postgres. Funciona, mas não é uma boa prática.
Há uma série de coisas que tornam este um mau exemplo a seguir e será muito difícil de dar suporte. Fico feliz que você tenha encontrado uma solução para você, mas não acho que este seja um bom caminho para as pessoas seguirem.
3 curtidas
Obrigado @pfaffman
Você está certo. Ele faz o trabalho, mas o procedimento é muito confuso. Está na ordem errada. Agradeço suas sugestões e vou corrigi-lo.
Você poderia esclarecer por que pensa isso?
Porque é complicado e é uma boa ideia apenas para pessoas que conseguem descobrir por si mesmas. É bastante ineficiente e, se o objetivo é apenas executar dois discursos, duas máquinas virtuais separadas são uma solução mais barata e fácil na maioria dos casos.
2 curtidas
Obrigado novamente @pfaffman – Simplifiquei o procedimento e removi a seção sobre a adição de um segundo site Discourse no mesmo servidor.
1 curtida
Recebi esta mensagem
sudo apt update \
uso: gpg [opções] --dearmor [arquivo]
curl: (23) Falha ao escrever corpo
Por quê?
Olá Antonio. Bem-vindo.
Isso parece um problema do Docker e não do Discourse. Você provavelmente terá mais sucesso pesquisando com seu sistema operacional e atualizando o docker-ce do que perguntando aqui.
Você está tentando usar o Discourse? Ou o CloudPanel?
1 curtida
Acabei de seguir o guia aqui. Executei o primeiro comando, para instalação do docker, e o servidor respondeu isto
o comando é:
1 curtida
Não deve haver barras invertidas no final de cada uma dessas linhas. A barra invertida escapa a nova linha, o que significa que o shell trata a próxima linha como uma continuação da mesma linha.
Neste caso, isso resultará em tentar executar isso como um único comando, que é de onde o erro está vindo:
sudo gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg echo \"deb [arch=amd64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu focal stable\"
Apenas remover essas barras invertidas no final das linhas resolverá isso:
echo \"deb [arch=amd64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu focal stable\" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt update
2 curtidas
Obrigado, agora funciona bem
2 curtidas
Obrigado @Simon_Manning – Removi as barras invertidas no trecho de código no tutorial da postagem principal.
2 curtidas
Desculpe-me, agora tenho este erro: FAILED
Pups::ExecError: /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end' failed with return #<Process::Status: pid 112 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params "/usr/local/bin/ruby -e 'if ENV[\"DISCOURSE_SMTP_ADDRESS\"] == \"smtp.example.com\"; puts \"Aborting! Mail is not configured!\"; exit 1; end'"
214c73c4474ed59e7b6fb7f42143ce126d2b453022b08770da3af31ca2fdaaba
Não conheço o CloudPanel, mas as mensagens de erro parecem autoexplicativas:
'if ENV[\"DISCOURSE_SMTP_ADDRESS\"] == \"smtp.example.com\"; puts \"Aborting! Mail is not configured!\"; exit 1; end'\"
Parece que seu e-mail não foi configurado durante o ./discourse-setup ou dentro do app.yml (você pode editá-lo manualmente a qualquer momento). :thinking:
2 curtidas
Com licença a todos, sou professor da escola secundária Fermi e estou tentando instalar o Discourse Community para nossa escola. Como usamos painéis de nuvem, segui este guia, mas aparentemente algo está faltando. É possível obter ajuda e um guia mais detalhado para seguir? Mil agradecimentos.
1 curtida
Acho que usar uma instalação avançada pode não ser o que você procura se você não tiver muito conhecimento de sysadmin. Outro ponto importante a considerar é que tal instalação se enquadrará em unsupported-install, tornando menos provável que você receba ajuda aqui se encontrar problemas.
Se você tiver o orçamento e dependendo do tamanho da sua comunidade, pode ser melhor hospedar o Discourse em outro servidor e seguir a instalação padrão.
1 curtida
Desculpe, e para que serviria um serviço como este? Na minha opinião, talvez o guia não seja muito detalhado, ele é feito para administradores de sistemas, bastaria indicar os vários passos. De onde eu venho, diz-se: ninguém nasce já educado. Obrigado pela sua ajuda e pelo seu tempo.
1 curtida
É exatamente isso. É por isso que a instalação padrão foi recomendada.
E é por isso, @denvergeeks, que eu não achei que criar um guia como este fosse uma boa ideia em primeiro lugar. É difícil de escrever, difícil de manter, e você é a única pessoa que pode verificá-lo.
4 curtidas
Lamento, mas não concordo. Já uso o Cloud Panel com vários domínios, além disso, a comunidade Discourse ficaria em um subdomínio e, então, a premissa do autor fica muito clara (o guia é para quem usa o Cloud Panel com diferentes serviços instalados no VPS). Basta um pouco de esforço para detalhar tudo melhor. Afinal, compartilhar conhecimento é a base das comunidades, senão eu teria comprado um software já instalado e pronto para usar. De qualquer forma, não quero incomodar ninguém, se for possível obter ajuda, então obrigado, caso contrário, não os incomodarei novamente.
1 curtida
@denvergeeks Configurar o e-mail é fundamental para a operação normal e, embora haja um link para a instalação padrão, a forma como o guia está escrito atualmente contorna a configuração do e-mail, bem como outras informações diversas que podem ser importantes para certas configurações.
Eu me pergunto se valeria a pena substituir as seções Instalar Discourse até Bootstrap the App por algo mais parecido com:
Instalar e Configurar Discourse
Siga a instalação padrão através dos passos 1-6
do_stuff_currently_in_edit_the_app.yml
Reconstruir Discourse:
./launcher rebuild app
Em seguida, na seção Parabéns!, adicione uma linha após a captura de tela para dizer algo como “Continue com o restante da documentação de instalação padrão.” Essencialmente, refatorando o guia para fornecer etapas adicionais que complementam a instalação padrão, em vez de fornecer instruções de instalação alternativas.
Acho que as informações que você forneceu sobre o CloudPanel são muito úteis e as instruções são claras, o lado do Discourse poderia apenas se beneficiar de ter menos divergência da instalação padrão para torná-la mais segura, bem como a tag unsupported-install para deixar claro (mais claro) que aqui há dragões.
2 curtidas
[quote=“Antonio Cirillo, post:18, topic:266422, username:Antonio_Cirillo”]
Afinal, compartilhar conhecimento é a base das comunidades, caso contrário eu teria comprado um software já instalado e pronto para usar. De qualquer forma, não quero incomodar ninguém, se for possível obter ajuda, então obrigado, caso contrário, não os incomodarei mais.
[/quote]A discussão se afasta um pouco do tópico original, mas tenha certeza de que ficaremos felizes em ajudar. :slight_smile:
Resumindo:
Se você tem conhecimento básico de TI, pode seguir a instalação padrão. Você também precisará de um nome de domínio e configurar um serviço de envio de e-mail, como o Mailgun (tutorial aqui: Configure Mailgun for email when using Digital Ocean for DNS).
Note que geralmente não ajudamos em questões que estão fora do escopo deste fórum. Por exemplo, a pergunta “Como registro um nome de domínio?” não se encaixaria aqui.
Se você não tem conhecimento básico de TI e dependendo do seu orçamento, pode solicitar suporte pago em Marketplace.
Finalmente, você também pode dar uma olhada nos planos pagos gerenciados do Discourse, onde praticamente tudo será tratado por nós e você terá acesso à nossa equipe de suporte.
Além disso, saiba que oferecemos descontos para fins educacionais, já que você menciona que é para sua escola:
Existem descontos educacionais ou sem fins lucrativos?
Sim! Se você for legalmente reconhecido como uma instituição educacional, oferecemos um desconto de 85%. Se você for legalmente reconhecido como uma organização sem fins lucrativos isenta de impostos federais, oferecemos um desconto de 50%. Esses descontos se aplicam apenas aos nossos planos básico, pro e business, não podem ser combinados com outros descontos e devem ser pagos por cartão de débito/crédito mensal ou anualmente. Entre em contato conosco após iniciar seu teste e adicionaremos o desconto à sua conta.
4 curtidas
