Discourse AI - Spamdetectie
:bookmark: This guide explains how to configure and use Discourse AI’s spam detection feature, including the setup process, scanning criteria, classification logic, customizations, and contrasts with AI triage.
:person_raising_hand: Required user level: Administrator
:megaphone: This is now default turned on for Starter and Pro customers, as well as our legacy Basic, Open Source, Creator, and Business customers.
Discourse AI provides an efficient spam detection feature that identifies and flags spam posts with minimal configuration. While designed for simplicity, it complements the more versatile AI triage system, which supports broader workflows and larger use cases.
Summary
In this guide, you will learn:
  • How AI spam detection works and what content is scanned
  • The classification logic and context used by the AI
  • Steps to configure spam detection through /admin/plugins/discourse-ai/ai-spam
  • Guidelines for Large Language Model (LLM) selection
  • Key differences between spam detection and AI triage
  • How to manage flagged and missed posts
What content gets scanned?
AI spam detection evaluates posts based on these criteria:
  1. User trust level:
    • Scans posts from users with trust level 1 or lower.
    • Excludes posts from higher trust levels.
  2. Post type:
    • Public posts (excluding private messages).
    • Both reply posts and first topic posts are included, based on additional thresholds.
  3. Post edits:
    • Scans posts with significant edits (e.g., changes exceeding 10 characters).
    • Enforces a 10-minute delay between scans of the same post.
  4. Post frequency:
    • Prioritizes posts from new users with fewer than 4 total posts in public topics.
    • Excludes posts from users exceeding this threshold.
The classification process
Posts that meet the criteria are sent to an AI model (LLM) for analysis. The model evaluates whether the post is “SPAM” or “NOT SPAM” based on:
  • Context: Includes post content, topic title, user account data (e.g., account age and trust level), and site guidelines.
  • Custom instructions: Admin-defined rules for reinforced or adapted scanning criteria.
  • Automated detection:
    • Flags irrelevant or promotional content (e.g., ads or commercial materials).
    • Identifies automated or bot-like behaviors.
    • Assesses content relevance to the discussion.
Default prompt and context
The AI uses a default system prompt to guide spam detection. This prompt outlines spam classification rules. For example:
You are a spam detection system. Analyze the following content and context.
Notes:
- Replies must remain relevant to the discussion thread.
- Mark as SPAM if the content is irrelevant, promotional, or automated.
- Consider new user posts with links as potential SPAM unless explicitly relevant to the topic.
Respond only with "SPAM" or "NOT SPAM".
The scanner also compiles a context package, including:
  • Metadata from topics and categories.
  • Relevance of replies to the thread.
  • Author data (e.g., account creation date, total posts, trust level).
  • Post text truncated to 5000 characters for processing.
Configure AI spam detection
Configuration guide
  1. Access settings:
    Navigate to /admin/plugins/discourse-ai/ai-spam.
  2. Select an LLM:
:information_source: If your site is hosted by Discourse
You can select our CDCK Hosted Small LLM from the LLM list.
  1. Activate spam detection:
    Enable spam detection by toggling the feature on.
:information_source: Note: A connected LLM is mandatory.
  1. Add customized instructions:
    • Define rules specific to your forum (e.g., stricter monitoring of external links).
    • Save any changes to apply them.
Differences from AI triage
While spam detection is designed specifically for identifying spam, AI triage supports broader post management tasks.
Feature AI Spam Detection AI Triage
Complexity Streamlined, opinionated setup Highly customizable and flexible
Primary use case Detecting spam with minimal overhead Advanced workflows for categorization, tagging, replies, spam detection, nsfw detection
Actions Flags spam, silences users Tags, categorizes, hides posts, adds replies, flags posts, silences users
Recommendation Easy setup and effective for most situations Use for rich highly customizable workflows
For more details, see Discourse AI - AI triage.
LLM selection recommendations
The performance of spam detection depends on the chosen LLM.
Most low-cost LLMs work effectively, such as:
  • GPT-4o-mini
  • Claude 3.5 Haiku
  • Gemini 2.0 Flash
Experiment with different models to find the best fit. Configure your models via /admin/plugins/discourse-ai/ai-llms.
Testing spam scanner behavior
You can test spam detection rules directly from the configuration page.
  • Paste a post URL or ID into the test field.
  • Review the classification result (e.g., “SPAM” or “NOT SPAM”) and analyze logs to understand reasoning.
  • Unsaved changes are applied during testing, enabling experimentation without risk.
Managing flagged and missed posts
Handling flagged posts
Flagged posts appear in the moderation queue. Admins can:
  • Approve legitimate posts wrongly classified as spam.
  • Reject spam topics to keep the system accurate.
:warning: Important: Reject spam flags for incorrectly classified posts. Users remain silenced until the flag is resolved.
Handling missed spam
Missed spam refers to posts bypassing detection but flagged by the community. Moderators can manage these as necessary.
Best practices
  • Monitor flagged and missed spam regularly to refine system accuracy. Clickable metrics simplify this process.
  • Use test cases to evaluate custom instructions against edge cases.
  • Review and adjust LLM settings when needed.
Additional resources
:mega: Configuring AI spam detection effectively reduces manual moderation efforts, ensuring a clean, spam-free community.
We’ve done quite a bit of testing with this, and we don’t seem to get reliable results at all. For context, we’re using the gpt-4o model.
To test its accuracy, I gave the following simple instructions:
Notes below. If *ANY* of the items are true below then mark it as spam:
- The username is very specifically "testjon", then it is *ALWAYS* spam.
- Respond only with "SPAM - It's Jon!" or "NOT SPAM".
Testing on a post, by the username testjon, results in NOT SPAM. It seems like it’s not heeding instructions well at all. Any suggestions?
Have any others had any good or bad experiences with the AI spam detection?
I don’t know how things are in this situation, but in general statement as quoted is very prone to break down. It doesn’t understand what ANY means and goes happily as long it gets. And from there it found at last NOT SPAM.
So you’re saying to remove the bolding for ANY? Or you’re saying the statement overall of “if any items below”?
I’m saying you have to write it more logical and exact. You can’t let an AI choose in any way. Remeber it can’t count and it defenetly not read first all and them come back and try to work logically. Try to explain so simple as you would give instructions to lazy ADHD 3 years old. Examples aren’t wrong but will increase use of tokens.
This is awesome info. For example, how might you write this exact scenario differently?
Something like…
You are a spam detection system. Your job is analyse silently content to keep up high quality in this forum. You must follow rules to define when a post is spam. When you find a spam, your respond is told in rules. You are using only told responses.
## Rules for spam
I don’t do this for you 😏 But you need some explanations and examples. Like as a fast&crude example:
* if a post has links to outside that are connected to gambling, sex, crypto etc. similar (similar is risky in this context, BTW), then a post is classified as spam. Example: www.buy-crypto.deal
This you must tune up case by cases, because you will get false positives and false negatives
Then you must give some guidelines to content too. But when testing:
* if username is ”testjon” skip analysing content and classify that directly spam. Your response is ”SPAM - it’s Jon”
BTW, can it see user?
## Rules for other content
When a post is passed spam analysing and you are sure it is legit content, your only response is ”NOT SPAM”.
Something like that. You have to test, of course. And everytime you get false response, try to find the confusing point. But don’t give to AI opportunity to choose what it can do, because it will then take the last, easiest or nicest direction. It has coded need to answer and be happy.
I have just enabled this and am excited to see how it goes!
Is there a setting or a consideration for the trust level users have?
For example: I don’t need the AI to kick in for TL2 and above, they have earned their place and should not be considered for scanning. If they do go rogue, we’ll have to have some words with them :sweat_smile:
2 posts were split to a new topic: Discourse AI plugin missing
Since this is replacing Akismet, I wonder what the best alternative is for spam detection/prevention if you don’t want the LLM costs that comes with AI?
Actually, Gemini 2.0 Flash is available for free, just as long as you aren’t of course sending a million requests to it each day. It’s working fine for my forum right now with zero cost, and it is defenitely more precise and “smarter” than Akismet.
However, if the AI Spam detection plan fails, I still have the Akismet plugin installed on my site and ready to go if I ever need it again, and I think you can still install it. (Since it is being deprecated though, I don’t expect it to stick around forever). Also remember that trust levels are a fundamental core of Discourse that help you manage spam on your site. :+1:
Oh that is cool, is it possible to put like a limit on tokens to make sure that the limit (zero cost) is there from the LLM?
As far as I know, I think if you exceed the limit the API for the LLM will just stop responding. My Google Cloud Console account does not have a billing account attached, and I can still use the API free of charge on the free tier, so you should be good. :+1:
Een bericht is gesplitst naar een nieuw onderwerp: Verbeteren van AI-spamdetectie voor bewerkingen en samenvoegingen
Waar krijg ik de “API-sleutel van de service die het model host”?
Als u op onze hosting zit, kunt u LLM Small gebruiken.
Als dat niet het geval is, moet u een LLM configureren en een sleutel verkrijgen van OpenAI/Google/Anthropic/X/whatever…
Oh, een API-sleutel van hen, niet van Discourse.
Enabling AI spam detection with Gemini 2.0 Flash doesn’t seem to have helped block this stuff. I’ve never had such obvious spam get through the filter before. Maybe it’s specifically designed for Discourse sites?
| QuickBooks Payroll Error After an Update +1-800-223-1608 Step- by- Step Resolution new | Americas - Canada | | 1 | 2 | 1h |
| Understanding QuickBooks Payroll Tax Table Update Error +1-800-223-1608 new | Americas - Canada | | 1 | 2 | 1h |
| Understanding QuickBooks Payroll Error PS107 +1-800-223-1608 new | Americas - Canada | | 1 | 2 | 2h |
| Full List Of QuickBooKs CusTomer™ SUPPORT®️ USA Contact™ Numbers : Your Expert Guide new | Americas - Canada | | 1 | 2 | 5h |
| Complete QuickBooks®️ Payroll & Error Support Numbers™️: 2025 Reference Guide new | Asia | | 1 | 2 | 5h |
| {Expert~ Guide} QuickBooks® Payroll Support® Contact Info – 2025 USA Guide new | Americas - Canada | | 1 | 4 | 5h |
| {Call@ +1-855-510-6777} How Can I Talk To ~$#Expedia Vacation Package Booking Support? new | Louisiana | | 1 | 6 | 5h |
| Complete List of™️ Caribbean Support™️ – The Detailed Official Guide new | Asia | | 1 | 2 | 6h |
| [Call^Agent^Direct] What Number Connects To Expedia Vacation Package Support? {Dial +1-855-510-6777} new | Americas - Canada |
Your API key is invalid, so it’s not doing any tests.
If you do a test at https://www.foodtalkcentral.com/admin/plugins/discourse-ai/ai-spam and paste in that URL you get a 500 error. If you wade into the logs in
/var/discourse/shared/web-only/log/rails/production.log and search for " 500 " you’ll see
Completed 200 OK in 399ms (Views: 123.1ms | ActiveRecord: 0.0ms (0 queries, 0 cached) | GC: 22.9ms)
DiscourseAi::Completions::Endpoints::Gemini: status: 400 - body: {
  "error": {
    "code": 400,
    "message": "API key not valid. Please pass a valid API key.",
    "status": "INVALID_ARGUMENT",
    "details": [
        "@type": "type.googleapis.com/google.rpc.ErrorInfo",
        "reason": "API_KEY_INVALID",
        "domain": "googleapis.com",
        "metadata": {
          "service": "generativelanguage.googleapis.com"
        "@type": "type.googleapis.com/google.rpc.LocalizedMessage",
        "locale": "en-US",
Oh, bedankt. Ik heb per ongeluk Gemini 2.0 Flash geselecteerd in plaats van Gemini 2.0 Flash Lite. Nu werkt het naar behoren.
