Un outil simple d'archivage pour Discourse
It seems that it’s pretty tricky to save an entire discourse site to a static version. According to this post by Jeff Atwood, it’s “much harder than you’d think”. It doesn’t appear that this is a priority for the Discourse team, either, which is perfectly understandable.
For my purposes, though, I found that I really needed some way to generate basic, static HTML versions of my Discourse sites. I’ve been using Discourse for a couple of years now as a discussion board when teaching my college math classes so, every few months, I retire one or two sites and start one or two more. Obviously, the discussions on the retiring sites have value so I really needed some way to save them. Ultimately, I figured I’d build my own tool.
The basic idea is simple: Rather than scan the HTML and use the HTTP protocol to crawl the site, I figured I’d use the Discourse API to crawl the site. You can view the result of applying the tool to this Discourse Meta on my webpage.
Before looking at it though, please temper your expectations. I’m a college math professor, not a professional web developer. And, while I’d like it to look pretty nice, I’m mainly interested in simplicity. My guess is that most folks here would consider this to be proof of concept, rather than a serious, working tool. Taking that into account, here are some features/limitations:
  • The code grabs the site logo and places it in a fixed banner at the top. If no site logo is found, it uses the site logo at the top of meta by default.
  • It uses the API to grab the topic list and generates a new page for each topic. You can limit the number of times you respond to more_topics_url.
  • There is a single main page that links to those topics.
  • MathJax is important for my needs so every page loads and configures MathJax.
  • There is no other JavaSciript and no other plugins are considered.
  • There are no user pages or category pages.
  • It’s not very configurable without messing with the code directly.
In spite of all the limitations, it’s sufficient for my needs and I’m rather happy with it. I have no particular plans to expand it, other than incrementally as needed. If anyone is interested, the code (which is Python) is available here:
Perhaps, someone will push it further or just be inspired by the idea?
We’re definitely interested in this, because sometimes you want to turn off all the fancy hosting and databases and render out a set of static HTML pages for permanent long term archiving with zero security risk.
With the meta topic, others can follow along and edit / contribute as needed.
You can also use our basic HTML version for archiving: this topic in HTML.
You can get this version using a crawler user agent.
Maybe this + recursive wget or similar can help you.
Yes, those links are gone, but it’s all summarized on this new page. Also, the output of the code as applied to this DiscourseMeta is now here. I even put it up on GitHub so maybe someone will get interested.
I’d like to edit the original post, but I seem to be past the edit window.
Incidentally, I do think that httrack works much better than I originally thought but I still strongly prefer my version for two main reasons:
  • My code explicitly supports MathJax, which is essential for my work.
    (I’ll probably need to update my code to work with the new MathPlugin sometime)
  • I’ve got much more control over what get’s downloaded and how it’s displayed. For example, I don’t like the way that httrack output points to user links, even if not downloadedl
I’m hosting a forum that is currently, in its third iteration, running Discourse. Our last two forums were (I think, phpbb2 or something like that). I have resolved to archive them using Discourse, so that:
  1. I scan the phpbb2 database into Discourse (there’s a migration tool)
  2. I create a static HTML archive using Discourse.
  3. I put up the static HTML archive into public use (preferably in the same place where our dynamic forum running Discourse is).
According to the first message
Could it be somehow advanced so that creating category views would be also possible?
Also, any help on how to use the Jupyter notebook thing? First time I hear of this…
@Silvanus Can you indicate a live discourse site that you want to archive? I’d be glad to try it out.
Also, have you tried httrack? I think that a command as simple as httrack yoursiteurl might work quite well.
I’m still in the phase 1 (phpbb2 > phpbb3 > discourse) of my archival, so no site yet. After I’ve managed the phpbb conversion, I’ll get back to this. It feels very, very hard. Been trying to install phpbb3 for a while now, but I get some weird problems all the time. :frowning:
I’ll have to try that httrack, thanks.
@Silvanus Well, I noticed that you point to the forum at https://uskojarukous.fi/ on your Profile page; I went ahead and created a couple of archives of that. You can (temporarily) take a look at the results here:
Here are a few comments:
  • I definitely like my version better; no surprise there because I designed it the way I want it to look.
  • The front page of the httrack version doesn’t look so great simply because that’s what the escaped fragment version looks like.
  • I think it might make sense to start httrack at a subpage to generate something like this.
  • It wouldn’t be too hard to make my archival tool grab the categories; I might do that for the next iteration.
  • My code adds MathJax to every page because my forums are mathematical. I should probably try to detect if MathJax is necessary. I’m guessing your forum doesn’t require it.
The httrack command
The httrack version was generated with a command that looks like so:
httrack https://uskojarukous.fi -https://uskojarukous.fi/users* -*.rss -O uskojarukous_arxiv -x -o -M10000000 --user-agent "Googlebot"
  • The -https://uskojarukous.fi/users* -*.rss prevents httrack from downloading files matching those patterns.
  • The -x -o combo replaces both external links and errors with a local file indicating the error. So, for example, we don’t link to user profiles on the original that weren’t downloaded locally.
  • The -M10000000 restricts the total amount downloaded to 10MB. There appears to be some post processing and downloading of supplemental files that makes the total larger than this anyway.
  • The --user-agent "Googlebot" should not be necessary if the forum is powered by a recent version of Discourse.
The archival tool code
For the most part, the archival tool should run with minimal changes. I run it within a Jupyter notebook but the exact same code could be run from a Python script with the appropriate libraries installed. Of course, you need to tell it what forum you want to download. The few lines of my first input look like so:
base_url = 'https://uskojarukous.fi/'
path = os.path.join(os.getcwd(), 'uskojarukous')
archive_blurb = "A partial archive of uskojarukous.fi as of " + \
  date.today().strftime("%A %B %d, %Y") + '.'
Later, in input 6, I define max_more_topics = 2. Essentially, that defines a bound on k in this code here:
'/latest.json?page=k'
But again, there should be some changes made to the code to get it to work for non-mathematical forums.
Very cool, thank you for all the clarifications. Just a quick note, it seems that your tool can’t handle sub-categories (which is why many of the messages seem to be without a category).
@Silvanus Yes, I think you’re absolutely right about the sub-category thing. Thanks - I had wondered about that.
@mcmcclur: as you already realized, I’m the admin of said forum, which is the third of our forums. When we did technological jumps, we didn’t migrate, but started from scratch, and the older forum was archived. The last two forums are in SMF format - but I finally managed to start converting them into Discourse format! :slight_smile:
So, our forum had a public area and a closed area. I’m thinking that the closed area (a few categories) should be archived, but closed off via a password gate. I noticed that the static paths are something like /t/TITLE/MESSAGEID/. This, if course, lends itself for thread-by-thread gating, but is slightly cumbersome - but, heh, I guess that’s what you get when archiving huge loads of stuff from a dynamic forum to a static archive… :slight_smile:
Quelques astuces pour toute personne cherchant des conseils sur httrack (qui fonctionne très bien pour mes besoins).
  • Une liste complète des options de ligne de commande : HTTrack Website Copier - Offline Browser
  • L’option -s0 ignore le fichier robots.txt (si vous avez un compte non accessible aux robots d’indexation).
  • Si votre site est protégé par une connexion, vous pouvez télécharger un fichier .txt contenant les cookies (une fois connecté) à l’aide d’une extension Chrome comme cookies.txt, puis placer ce fichier dans le répertoire depuis lequel vous exécutez httrack.
J’utilise httrack via cron pour créer une archive hors ligne de notre site Discourse. Cependant, l’utilisateur qui se connecte via httrack est comptabilisé comme une « vue » pour chaque sujet, ce qui gonfle considérablement le nombre de vues par sujet (le cron s’exécute toutes les heures).
Existe-t-il un moyen d’exclure un utilisateur spécifique des statistiques de vue du site dans son ensemble ?
Good point, where would this be intercepted @sam?
We have this method for tracking page views:
We have additional methods for tracking user visits which would be even harder to override.
We only store one page view per day per user, but I get that it can add up.
Hacking this out so certain users are not tracked would either require a plugin or some sort of daily query that nukes all the views by the user and remembers to also reduce views count from the topics table.
Hi all – just jumping in here to say that @mcmcclur’s code was exactly what I was looking for! So thank you very much for sharing :slight_smile:
I made a few small modifications (mainly additional code that makes sure to grab all posts in a topic, not just the first twenty) and the code is here: GitHub - kitsandkats/ArchiveDiscourse: Code for archiving a Discourse site into static HTML., forked from @mcmcclur’s original repo and stored as a python file instead of a Jupyter notebook.
I’m very happy with how it turned out. Thanks again!
Bonjour, je viens de parcourir tout ce fil et je voulais savoir si cet outil fonctionne si le forum Discourse est protégé par un identifiant et un mot de passe. Comment modifier le code pour permettre l’archivage du site ?
Tel qu’il est actuellement rédigé, le code n’est pas conçu pour accéder à des éléments nécessitant une connexion. Cependant, cela devrait être assez simple à mettre en place. Le code interagit avec le site Discourse via la bibliothèque Python Requests, qui propose une authentification. Il est tout à fait envisageable que l’ajout de auth=('user', 'pass') au code aux endroits appropriés soit la seule chose nécessaire. Je ne fais pas actuellement tourner de site Discourse, je ne peux donc pas tester cela pour le moment.
httrack ne fonctionne pas pour moi. J’utilise :
httrack https://my-forums.org --user-agent "Googlebot"
httrack est très prometteur, mais les longs fils de discussion du forum sur plusieurs pages sont incomplets. Dès que je clique sur « page 2 », cela ne fonctionne pas. C’est-à-dire que :
  • file:///home/user/My%20Web%20Sites/my-forums/my-forum.org/t/forum-thread-title/83394658.html semble vraiment bien (ne charge pas les ressources externes), mais
  • file:///home/user/My%20Web%20Sites/my-forums/my-forum.org/t/forum-thread-title/83394658.html?page=2 est cassé.
Des suggestions ?
Peut-être que httrack peut être configuré pour « utiliser le mode impression » ?
Peut-être que httrack peut être configuré pour « ajouter /print à la fin » ?
Existe-t-il un paramètre d’user-agent qui affiche tout le fil de discussion du forum sur une seule page ? Sinon, pourriez-vous ajouter cette fonctionnalité ? Vous avez déjà mis en œuvre le mode impression. La plupart est déjà implémenté. Il ne reste plus qu’un user-agent qui fournirait au crawler le contenu généré pour le « mode impression » ? Alternativement, si vous n’aimez pas l’idée d’un user-agent personnalisé à cette fin, qu’en est-il d’un en-tête HTTP ou d’un cookie qui pourrait être utilisé à cette fin ?
ArchiveDiscourse amélioré/forké par par @kitsandkats est également cassé pour moi.
Pourriez-vous également envisager d’implémenter /print pour les pages d’accueil et les pages de catégories ?
Je me cite dans https://meta.discourse.org/t/i-dont-like-infinite-scrolling-and-want-to-disable-it/104660/3
Désactiver (temporairement) le défilement infini (pour certains user-agents) rendrait possible l’archivage de Discourse avec l’outil d’archive web httrack.
Les requêtes Python utiliseront automatiquement le fichier .netrc pour l’authentification si nécessaire (mais il faut qu’elles reçoivent une réponse HTTP 401).
J’ai obtenu de bons résultats avec wget, y compris pour l’authentification. Décrit ici :
https://meta.discourse.org/t/archive-an-old-forum-in-place-to-start-a-new-discourse-forum/13433/14
