האם קיימת דרך לראות יותר מ-50 תוצאות when searching for text to customise?
סיכום מבוסס בינה מלאכותית
The discussion revolves around increasing the maximum search results when customizing text, currently capped at 50. Jonathan5 referenced a previous discussion and a GitHub file for client translations, but seeks a more convenient method to view additional results. maiki suggested using Data Explorer as an alternative approach. Jonathan5 shared a specific use case, customizing the sidebar, and proposed implementing a filter system similar to the “Settings” menu to make it easier to view all relevant results.
Continuing the discussion from Renaming system text when there are more than 50 results:
I’ve bookmarked the file above, but it would be handier if I could increase this maximum to something like 100 or 200, or whatever is needed to get all the results. Is there any way to do that?
Hi @Jonathan5. Maybe you could use Data Explorer to query what you are looking for.
If you explain your use case, there may be another approach. :slight_smile:
I was looking for stuff to do with the sidebar to customise. But I’ve been frustrated by this several times.
With the “Settings” there is the ability to filter using the sub-menu/categories, and so see everything. It would be good if something like that were possible with “Customise - Text”.
