更新后管理员端崩溃
您好,
刚刚更新后,我无法看到管理员仪表板,页面是空白的。
当我尝试重建时,我得到了这个:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle
 exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 1051
 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/exec_command.
rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "tag"=>"precompile", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile'"]}
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may
be more than one.
你能向上滚动查找错误并在此处分享吗?
2 个赞
rake aborted!
Zlib::BufError: buffer error (Zlib::BufError)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cache/file_store.rb:100:in `<'`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cache/file_store.rb:100:in `set`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cache.rb:212:in `set`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cache.rb:136:in `set`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:243:in `store_asset`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:185:in `load_from_unloaded`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:60:in `block in load`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:317:in `fetch_asset_from_dependency_cache`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/loader.rb:44:in `load`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cached_environment.rb:20:in `block in initialize`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/cached_environment.rb:47:in `load`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/base.rb:66:in `find_asset`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/base.rb:73:in `find_all_linked_assets`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/manifest.rb:134:in `block in find`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/manifest.rb:133:in `each`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/manifest.rb:133:in `find`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/sprockets/manifest.rb:186:in `compile`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-rails-3.5.1/lib/sprockets/rails/task.rb:67:in `block (3 levels) in define`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-3.7.3/lib/rake/sprocketstask.rb:147:in `with_logger`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sprockets-rails-3.5.1/lib/sprockets/rails/task.rb:66:in `block (2 levels) in define`
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
最近有几个人遇到了这个问题(包括我 :slight_smile:)。对我来说,起作用的是这个建议:
3 个赞
我刚读了同样的内容。我现在就试试。谢谢。
1 个赞
重建已完成。但问题仍然存在。当我点击我的个人资料时,没有任何反应。网站标志也在闪烁 :slight_smile:
:partying_face:
下一步,您能否尝试安全模式,看看是否有主题组件或自定义代码干扰?
您能否也检查一下您的 /logs 以获取更多详细信息,以及浏览器控制台。
4 个赞
已修复。非常感谢。@JammyDodger
1 个赞
