Automatic Night Mode Plugin
Some users have been asking about automatic switching between a light and a dark theme. Could this be accomplished with a plugin?
I assume this would need two parts:
  • a theme component with a javascript switching themes based on local time
  • a Discourse plugin adding options to the user preferences page:
    turn night mode switching on/off, choose nighttime theme, set time nighttime time period
How difficult would it be to code? As in, how much would it cost?
That would be AWESOME!
With a plugin for sure, a bit harder to swing as a theme component.
If you reuse the logic in chronos by @j.jaffeux it will probably be not too hard. I would say 2 days of work if I had to pull out a number.
Is this still the case today?
This can be done in a theme component these days
Is there any guide or example code to add editable user custom fields with a theme?
Why a theme when you can manage user fields in admin UI (/admin/customize/user_fields) itself?
Until you find a solution, use this theme component as a placeholder: it’s for Macs. I know it’s not exactly what you need, but figured it may help.
I mean to create custom user preference like time selector that can be saved with a theme. Is that possible these days?
With a plugin, I had to register the custom field as editable with register_editable_user_custom_field so it can be saved.
I believe @pmusaraj was looking at this last.
Is it possible to have a day - night switch on Discourse with a theme component?
Need this for sure. Will be keeping an eye on this topic to see if anything updates.
I don’t think we support custom user fields in themes at the moment. I do see the use case for them though, it’s nice to be able to ship a theme component with a user-configurable setting.
There is a fairly hacky workaround, to add a field in the UI only and then store the data in local storage or the session. That’s what I did on the experimental automatic dark mode switch for Safari, you can look at the code of that component to see how it’s done.
I made a theme component for anyone who interested:
