Howโs mobiles? Normally something like 80 % or more are using mobiles and for them sidebars are useless. Will they see something or is this only for desktops and tablets?
Just to summarise a few changes that have occurred recently:
Iโve added support for Right Sidebar Blocks too
Iโve partially migrated it to Glimmer (the widget invokes a Glimmer Template)
Iโve added caching to prevent frequent calls to tags.json (which it was calling with each page change!) - if you want to see a new tag you must refresh your browser. This will alleviate:
As part of a migration to remove all legacy Layouts and Discourse Widget code, this has been fully migrated to Glimmer, relocated and the Component renamed, you might need to update your Bars or RSB config:
Repo now at: https://github.com/merefield/discourse-tc-bars-tag-list-component
