Hi,
We are heavily using this plugin which is great, however our tags are getting quite extensive, it would be great if there was a way on the Left where the tag list shows up, to search and or narrow down the possible tags.
Once you have a few hundred tags available things get unruly real quick
What you’re asking for is a way to search the tags on the left sidebar? Is that correct?
Hi Justin
Yes being able to filter and or search for tags on the left side bar would be a huge help. We are developing a really extensive knowledge base and the list is getting LONG!
–Chers
Check this out.
