Categorieën Tag Kolom
The Categories Tag Column theme component adds a column displaying tags to the categories page. It can be installed from the repository link.
The component offers layout flexibility, with settings for the column and row of the topics and tags. nplanchon requested guidance on replicating a specific layout, which awesomerobot provided.
IT_Director asked if it’s possible to display the tag column on the landing page, and later found a solution by setting the top menu to ‘categories’. However, IT_Director reported a bug where only tags from the ‘Other tags’ group are pulled in when tag groups are enabled.
nplanchon reported an issue where the tag names disappeared after a few days of stability, and awesomerobot was asked for guidance on troubleshooting.
Other users, including mattdm, sunjam, and Chris_Neidl, have requested additional features, such as support for tag groups and the ability to enable tag columns within specific categories.
:discourse2: Summary Categories Tag Column adds a column displaying tags to your categories page.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-categories-tag-column
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
:information_source: This component only works if the desktop category page style site setting is set to either categories and latest topics or categories and top topics.
Features
Settings
Name Description
tag count Change the number of tags that appear by default. When only a subset of tags is shown, you’ll also get a “more” button.
categories page column count This controls the number of columns on the page in total. Note that when the browser is less than 768px wide, all the content will stack into a single column.
tag column count The number of columns used within the tags section
hide categories column Enabling this will hide the categories, this may be useful for sites that want to focus on tagging
categories column The column categories appear in
categories row The row categories appear in
tags column The column tags appear in
tags row The row tags appear in
topics column The column topics appear in
topics row The row topics appear in
:information_source: Note that the column and row settings accept values that work with grid-column and grid-row… so for example, by default the topics_row value is 1 / span 2, this means topics start in row 1, and span across 2 rows. So as seen in the screenshot above, the topics column is as tall as both the categories and tags columns, which are only 1 row high.
The row and column settings grant a lot of layout flexibility. With a few changes, you can change the layout to something like this:
or this:
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
It’d be amazing if this could support tag groups!
Thank you for creating and sharing this out @awesomerobot. I am confused and would love some handholding to create this layout on our instance. I want to exactly replicate this screenshot. Would you be willing breakdown what each setting needs to be set at for that?
and @awesomerobot, how can I sort them by name rather than count?
and is there a setting which makes showing all tags all the time, rather that having a More button? @awesomerobot
Cheers
Neil
Sure no problem… from the default settings, you’d change the following:
tag column count: 8
tags column: 1 / span 2
topics row: 2
you can make the tag count setting higher, to something like 999 perhaps?
There’s no option for this at the moment
Nice to hear from you and thank you @awesomerobot
Hi @awesomerobot, many thanks for this!
Is it possible to not just show it under /categories, but instead on the landing page?
We currently have it implemented under FIC Forum
…but we’d like to have it implemented on the landing page: https://forum.ic.org/, making the end result look like so:
Is there a way?
…actually I think I found a way - settings > basic setup > top menu: set the first to ‘categories’ and this makes the start page view default to the above.
:smiley:
This might be a bug @awesomerobot: if one has tag groups enabled then only tags from the ‘Other tags’ group are pulled in.
To replicate:
  1. Enable tag groups
  2. Add tags in a group
  3. See that only the tags not belonging to the ‘Other tags’ group are visible
@awesomerobot Hello Kris. Sounds like you might be able to guide me on a new anomaly. If you can great, otherwise, I am at ease with starting a new thread.
After a few days of stability using the theme component which adds tags on the left side of our /categories page, this morning all the names of the tags have disappeared and it looks like this! I have also attached what it looked like after we successfully installed the component and set it up the way we like it best.
What do you think is causing this behavior?
What steps can I be taking to troubleshoot?
I know that I can ever so easily revert to the original /categories page and set it up again. I need help from others who have more experience than me. First asking for support. :smiling_face:
I look forward to hearing from you.
Cheers!
Neil
This is awesome. What I would like is to specifically enable tag columns within particular categories, so users are encouraged to browse by tag.
I’m also looking to do this. Did you figure out how @sunjam ?
:face_with_raised_eyebrow: this makes way more sense.
