Beta8 upgrade stuck halfway
The user adamengst reports that their Discourse upgrade to beta8 is stuck in the “compressing” phase for over 30 minutes, with no progress after several hours. The upgrade process appears to be halted during asset compression, specifically for JavaScript files like application.js and sr.js. Despite the site remaining mostly functional, the user is concerned and considers resetting the upgrade. Denis_Heraud suggests using the command line to rebuild the app, which adamengst confirms resolves the issue. zogstrip explains that asset bundling is CPU-intensive and can take hours, but adamengst notes the process never progressed beyond the stuck point. Another user, sarafina, confirms similar issues with a different beta version, and codinghorror recommends using the command line to force the upgrade.
I started upgrading through the Web interface, first docker, which went fine, and then the main Discourse upgrade to beta8. That seems to have gotten stuck (for 30+ minutes, with no change) in a “compressing” phase.
The site seems to still be working mostly, although I couldn’t get to a private message. I’m planning to click Reset Upgrade unless someone says not to right away. :slight_smile:
Here are the last two lines of the log:
Compressing: locales/sr-53d537749608d7dfdfcd3a2581d2afb1dfa2447813239a81a56398a9e6b6e5e6.js
uglifyjs '/var/www/discourse/public/assets/locales/_sr-53d537749608d7dfdfcd3a2581d2afb1dfa2447813239a81a56398a9e6b6e5e6.js' -p relative -c -m -o '/var/www/discourse/public/assets/locales/sr-53d537749608d7dfdfcd3a2581d2afb1dfa2447813239a81a56398a9e6b6e5e6.js' --source-map-root '/assets/locales' --source-map '/var/www/discourse/public/assets/locales/sr-53d537749608d7dfdfcd3a2581d2afb1dfa2447813239a81a56398a9e6b6e5e6.js.map' --source-map-url '/assets/locales/sr-53d537749608d7dfdfcd3a2581d2afb1dfa2447813239a81a56398a9e6b6e5e6.js.map'
gzip -f -c -9 /var/www/discourse/public/assets/locales/sr-53d537749608d7dfdfcd3a2581d2afb1dfa2447813239a81a56398a9e6b6e5e6.js > /var/www/discourse/public/assets/locales/sr-53d537749608d7dfdfcd3a2581d2afb1dfa2447813239a81a56398a9e6b6e5e6.js.gz
Compressing: application-925ac82337cd3f887f7ac5a86e5cb6081076cf526ae4d0c8ae77c2a8596f7aa7.js
uglifyjs '/var/www/discourse/public/assets/_application-925ac82337cd3f887f7ac5a86e5cb6081076cf526ae4d0c8ae77c2a8596f7aa7.js' -p relative -c -m -o '/var/www/discourse/public/assets/application-925ac82337cd3f887f7ac5a86e5cb6081076cf526ae4d0c8ae77c2a8596f7aa7.js' --source-map-root '/assets' --source-map '/var/www/discourse/public/assets/application-925ac82337cd3f887f7ac5a86e5cb6081076cf526ae4d0c8ae77c2a8596f7aa7.js.map' --source-map-url '/assets/application-925ac82337cd3f887f7ac5a86e5cb6081076cf526ae4d0c8ae77c2a8596f7aa7.js.map'
OK, I guess Reset Upgrade may not be what I should do. Suggestions about how to get past this stuck upgrade?
Have you tried running ./launcher app rebuild in a terminal?
No, since I’ve only dealt with Discourse at the interface level so far and would have to get my developer to do that. If that’s the fix, I’ll get him do that.
Also, I just wanted to make sure the developers knew that the install was failing, since it might be indicative of some bug. I have the log of the install so far saved out.
Ya, it sounds like there isn’t much more you can do through the admin interface.
And indeed updating through the command line worked fine. So the devs should just consider this an anecdotal bug report with the beta8 installer.
I don’t see a bug here. Asset bundling is the most CPU intensive step in the upgrade process. Depending on your CPU it can take a couple of hours to finish…
It never progressed from the point where it stopped, despite running for 4 more hours. Which seems wrong.
Chiming in here that we are stuck as well on the
discourse
v2.3.0.beta3 +20 update.
I am seeing this;
New Version Available!
  • Remote Version: v2.3.0.beta9 +48
  • Last Updated: 9 hours ago
  • 926 new commits
    With a blue box and ‘Currently Upgrading…’
    It’s been like this for weeks.
I suggest SSH-ing in and updating at the command prompt.
cd /var/discourse
./launcher rebuild app
