Guest Gate (Sign Up Popup Plugin)
#1
This is a more permanent post for a plugin that @vinothkannans created and I forked recently. Many thanks to @vinothkannans for doing the hard work of wiring up the main logic, @ljpp for stirring the original conversation, and @DiscourseMetrics.com for providing the impetus behind a customized modal.
You can see it in action on my site after a few hits to a topic: https://graphme.io
As with all plugins, this is how you add it:
- git clone https://github.com/jgujgu/discourse-guest-gate.git
You have two main gate options in the plugin:
  1. Generic gate
  2. Custom gate
And tertiary options:
  1. Number of topic views until gate displays. After the gate first appears, it appears randomly between 1 and this number.
  2. Disable x button
  3. Various styling options for custom gate
Here is a screenshot of the admin panel:
And of the plugin in action:
The desire for a plugin like this was discussed in this topic. I hope to add functionality as time goes on, but here is a short list I hope to take a poll on:
  • Timer
  • Inverse Timer (Read time > t)
  • Display on every page
  • Stubbornness (after x many times closed, give up asking during this session/use default discourse functionality)
  • Track how often it gets closed, other metrics
  • Track whether user signed up through overlay (could just put user in specific group)
  • Appear given a specific url (eg https://yourdiscourse.com?iscool&referrer=reddit). Like an invite link, but could put signups in particular group, like the above
0 voters
Force signin plugin
Force signin plugin
A Popup Box which close after 10 seconds or after Liking FB page
Is the "Discourse-Gate" plugin harmful for SEO?
Trying to hyper-target our lurkers and incentivize sign-ups 🚀 (and run a JS on login)
Blank page after upgrade due to broken plugin
My site is broken due to an incompatible plugin
Private vs public site and sharing topic links
Show topic title even if you don't have access
Adding a call-to-action for donations with our Patreon plugin
More aggressive method for asking users to register? (Call to action)
#2
This is the best solution to boost signup, because visitors want to “see” before “buy”.
I used this method on my forum for 1 year. And now i have 35 signups per day, instead of 3-4 before the plugin.
(Chris Beach) #3
Interesting and thanks for sharing. I don’t mean to sound skeptical, but this increase in signups may relate to other factors including the organic growth of your forum over time.
Can I propose a better test? If you were to alternate between Guest Gate and normal signups each week for a month we’d have some good comparative data to show that Guest Gate works.
#4
The subscription bump was from one day to the next (not after one year) :wink:
You know, with the SEO, many came to read about their keyword search, but don’t want to signup. It’s a good way to convert search traffic.
(Fer Nando) #5
Have an option to disable for GoogleBot?
This plugin is a good idea, thanks for share it.
#6
I made 2 more additions today
  1. Per @Fer_Nando’s suggestion, I added a list of bots that should not open the modal. I found the list in this Stackoverflow answer
  2. I added gate_show_only_once as an option, which will, as it says, only show the user the gate once per hard refresh.
I’ll keep my eye on the poll for the next feature to add. :grin:
(Tobias Eigen) #7
Thanks for the sweet plugin! I’ve installed it on my community and really like it. :rocket:
Those are unfortunately all equally good ideas. :slight_smile: All worthy of implementation, and I couldn’t tell you the priority of each.
(Vinoth Kannan) #8
I guess no need to exclude bots here. Since Discourse uses crawler layout for bots. Also there is function to detect bots and layout. Check below
(Vinoth Kannan) #9
I appreciate this @jgujgu’s forked plugin and I recommend it because of his active development in new features. Also if anyone need simplified version of this plugin with minimal features you can still use my original repo at GitHub - vinothkannans/discourse-guest-gate: Forced login / registration popup insired by Quora. It will give you output like in screenshot below and you can configure how many topics a guest can view before displaying the guest gate.
(Fer Nando) #10
Thanks for your work!
(Veer) #11
@vinothkannans i want the same popup plugin but not for sign up, but for facebook page likes, or for twitter followers. i can pay to you for this.
Please check this.
#12
Hi!
The plugin has incorrect (outdated?) modal.hbs template:
      <div class="modal-inner-container">
        <div class="modal-header">
          <a class="close" {{action "closeModal"}}>{{fa-icon "times"}}</a>
          <h3>{{title}}</h3>
          <div class="clearfix"></div>
        </div>
The .close anchor should be wrapped in div with modal-close class.
It has several consequence:
https://meta.discourse.org/t/dialog-close-button-design/60727/?source_topic_id=56625
https://meta.discourse.org/t/dialog-and-esc-handling/60725?source_topic_id=56625
PR: fix broken layout in modal.hbs: added .modal-close by evil-shrike · Pull Request #3 · jgujgu/discourse-guest-gate · GitHub
Probably a bug relative to the close button on banner topic
#13
@jgujgu
@Shrike
@vinothkannans
Could you please remove the bottom block that says “Log in | Create New Account”
Reason:
Users are clicking on that link and then in the next screen, they are finding the close button. That way they click on the close button and read the content without registering for an account.
#14
Just updated to Discourse v1.9.0.beta11 +12 - this plugin breaks site.
(Wiliam Joaquim) #15
I did the installation and broke the site. :slightly_frowning_face:
The site has been left blank for members, nothing uploaded.
Only I with my admin account logged in I was able to access the site normally.
VERSION: v1.9.0.beta11 +12
#16
Once I logged out of admin I had the same issue - then couldn’t log back in. SSH in - remove plugin - rebuild.
#17
I also just removed this plugin.
After the new Discourse Update - I’m getting a blank page - because of this plugin - So, I had to remove this plugin to fix it.
@jgujgu
Thought of letting you know - so that you can fix it, if you have some free time.
I'm paying to fix the discourse-gate-plugin
(Bryan Holst) #18
I’d love to know when this works again! I’d love to have this working on my site!!
(Tobias) #19
We’re also facing the same problem after the latest update. From our end, it was possible to fix, by disabling the plugin in the Admin-panel.
(Erlend Sogge Heggen) #20
Seems like @jgujgu has abandoned this. The website he was using this on is no longer operational.
@vinothkannans are you still maintaining your original plugin for this?
