Can i run Discourse on my Main Domain?
Hi,
This is my first post. I am trying to self install discourse, can i use my main domain for this installation instead of a subdomain?
Yes. Most people have another site that they run on example.com, but if you don’t, you can put Discourse there.
Thanks @pfaffman. DOne with settings… I think i broke something at the email section as i mistakenly tapped the enter button twice, skipping both SMTP user name and SMTP port [587]:
Can i delete what i have done so far and restart the process? Thanks
Yes. But it’ll ask you if everything is right before it gets started.
cd /var/discourse
rm containers/app.yml
Opps… Got this >>>> rm: cannot remove ‘containers/app.yml’: No such file or directory
You have to do cd /var/discourse first
Thanks @Steven got same response no such file.directory found, is it possible i destroy this droplet and start all over again?
It’s more likely that you didn’t hit return enough times for it to create the file. Just run ./discourse-setup again.
